Question about Toshiba Televison & Video
I need the code/codes to setup a Westinghouse universal remote model # WSTR004 to comply with a Toshiba tv serial # RC101018424
Posted by Cali Blackwell on
5 Related Answers
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: tv remote setup code for toshiba
Remote codes
http://www.remotecentral.com/index.html
Posted on Feb 22, 2008
Anonymous
SOURCE: wHITE-WESTINGHOUSE TV/VCR COMBO NEED CODE
The code for the TV is 0623 but to use the TV/VCR button to change mode from line to TV the code is one of the following 0179, 0451, 0463, 0624 or 0278. The 0623 only activates the menu but doesn´t let you change Air/Cable mode without first changing the Line/TV mode by pressing the TV/VCR or Line input button on your universalk remote with one of the other codes.
Posted on Feb 03, 2009
Anonymous
SOURCE: Need remote codes for Toshiba TV/DVD combo Model sd-p4000
code list for philips remote for my toshiba TV
Posted on Apr 01, 2009
Anonymous
SOURCE: rca remote control code list
i need the codes for a rcu404 universal remote for sony dvd player
Posted on Aug 23, 2009
tuckertj69
thomas colvin jr
SOURCE: Programing universal remote for Toshiba TV
toshiba 32a41 code
Posted on Jan 11, 2014
Toshiba store tv
To choose the right remote control, you have to know about the setup codes to your brand device. To get more details about the setup codes, check the sites linked here. It has setup code list and setup procedure to many popular brand remote controls. Check it, find out which brand remote control have setup codes to your device, and buy that brand universal remote control, according to availability. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 10, 2013 | Universal Remote Control Televison & Video
Remote to an OLD Toshiba TV (model 37a33) is lost and I'd like to replace it OR possibly use cell phone for IR signal. Reason is I want to change video source but TV does not have button to allow it. Any...
If you wish to buy its original remote control, contact the authorized service center for Toshiba. If you wish to buy a universal remote control, check the code list to the remote control you do buy, have set-up codes to Toshiba TV. Setup codes to Toshiba are
1088 1077 1061
1070 1203 1423
1093 1466 1048
1213 1047 1141
1046 1231 1144
1276 1054
If you wish to get more details, check the sites linked here. It has setup code list and setup procedure to many popular brand remote controls. Check it, and find out which brand remote control have setup codes to your Toshiba TV, and buy that brand remote control according to availability. Brand name to a universal remote isn't a matter, but it should have setup codes to Toshiba. http://remotesearch.blogspot.com/
Sep 05, 2013 | Toshiba Televison & Video
Toshiba won't function with remote
All universal remote controls should have to setup with the TV by its codes. There are codes, given below, to synchronize the TV with remote control. Brand name of the remote control you have isn't matter. Check these codes. Proceedings also is given. If you want further details, check this link, and select the site 'Electro-help'. pull up older posts there for more details.
Setup codes for Toshiba TV are:
0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jul 10, 2012 | Toshiba 46 46SL412 TV
Need remote control for westinghouse tv model sk-32h510s. will be happy to submit purchase info aand acct. number if you can guantee me that this remote is available.
Hello
Just buy one RCA RCR 4373 Universal remote control. Westinghouse Tv is listed in its codes. Codes are:
1217, 1036
You will get instructions and other proceedings to setup it with your TV. It can be bought from most of the electronic sparepart shops at your town or from "Ebay" or "Alibaba.com" by E-payment. [PayPal].
Aug 24, 2011 | Westinghouse Televison & Video
I have a Philips CL043 universal remote. I can't find th tv code for a Westinghouse lcd tv.. can you help?
You can find codes for the remote here: http://www.urc.philips.com/ . Then look up the CL043 and click on the remote code finder. This is also called the SRU3004WM by Philips.
A Westinghouse TV should responds to one of the following codes: 0915, 0013, 1216, 0300 if the TV was released 6 months before the remote was programmed or earlier. (Whte Westinghouse codes are different.)
If those codes do not work, there is a manual code search option. With the TV on, press and hold Setup on the remote until the red indicator stays lit. Then press and release quickly the TV button on the remote (the LED will blink once). Then press the Channel Up button until the TV responds (up to 300 times). If you overshoot, press Channel Down to go back to the previous code. Press and release the Mute button to set the code. Check if the remote performs all the needed functions. If it doesn't, repeat the above steps to find another code.
I hope this helps.
(if the remote is older than the TV, you may need a newer universal remote.)
Jan 08, 2011 | Philips 5-Device Universal Learning Remote...
I need the programming code for a universal remote and a westinghouse tv model number sk26h570d
Hello, the Westinghouse TV's are able to use only the Sony codes for the universal remotes, other than that I would recommend emailing the Westinghouse parts department at [email protected] and requesting an original remote for your unit, the price on the remote is $15 plus shipping and handling.
Nov 22, 2009 | Philips PM3S Remote Control
Remote code
Hi beutyful24_7,
There are two codes for your remote that work with White Westinghouse TV models: 311 and 611.
For your reference, here is a web address that includes all the codes for your remote, along with programming instructions:
http://www.universal-remote.net/philipsmagnavox.html
I hope this helps - please let me know if I can be of any further assistance.
Dec 11, 2008 | Philips Magnavox Learning Universal Remote
Remote code
DirecTV offers a remote code lookup tool, which I just used to find possible codes for my Westinghouse TX-42F430S; its first suggestion (the "most popular" code) didn't work. Clicking the "It's not here" button showed seven more codes, and one of them (11577) worked perfectly. Here is the full list of Westinghouse codes for DirecTV from that tool (as of 11/27/08):
Most Popular Code: 10885
Other Possible Codes: 10889 10890 11577 11282 10451 10000 11092
Nov 10, 2007 | Westinghouse 16093 Remote Control
Open Questions:
Televison & Video Logo
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
