SOURCE: power cord
Yes that is the green one to ground check out this website. http://fixitnow.com/appliantology/dryercords.htm let me know if it helps..
SOURCE: connecting 4-wire recectacle 14-30r dryer
doesn't matter both are 110v lines but if you want look up to top screw connections the wires coming to those screws are also colored as long as the red and black are to outside screws dryer will work ok
SOURCE: hooking up the four prong cord to the dryer
this is the rule of thumb,white always goes on the middle terminal ,the 2 outside terminal wires it does not matter which side they are on,if you can see the red and black wire on the terminal block then match them up,the green wire gets mounted to the cabinet,you should already have a green wire to the cabinet so remove the screw and put both wires there and your done,let me know how you do-mike
SOURCE: Screw Size to install electrical cord
they should be what is called a 10x32 screw. you should be able to get these from any hardware store. not at home depot or lowes, but like an ace hardware. they will know what you are talking about.
i would guess that someone lost your original screws. if not then you might be having problems because the screws got stripped out when trying to change the cord or hook up a new one. if that happend, then you will need to replace the nuts also. get them at the hardware store too.
it may not be easy but you will save alot of money if you can do this yourself.
