Question about Manitowoc Kitchen Appliances - Others
Have a manitowoc ice machine, model qd0212a. Not working. E When I turn it on I hear a sound like a tripped breaker inside the unit. Any ideas?
Posted by Chuck Fradley on
5 Related Answers
Anonymous
  • 540 Answers
SOURCE: AC breaker trips after 10 minutes
Whats the amp breaker? Is this for the inside unit or the outside condenser? If the inside and gas heat you have a bad fan motor, If its an electric furnace , the same, but if its the outside unit, the fan could be going bad, locking up and the compressor still runs and pulls high ampsand tripps breaker or the compressor is just pulling too many amps due to plugged coils with dirt , grass or weeds blocking airflow.([email protected])
Posted on Jun 09, 2008
mike bare
  • 116 Answers
SOURCE: is there a reset for the a/c unit itself
check for fuses in disconnect at the out door unit or a reset button where the copper line set goes into the unit at make sure stat wires have not been damaged hope this helps
Posted on May 15, 2009
dieselpro
  • 183 Answers
SOURCE: breaker keeps tripping on outside air conditioner unit
The compressor is probably drawing to many amps. Breaker could be weak also.. Need to check the amp draw on the compressor.
If the breaker is hot when it blows, the compressor is probably going bad.
Posted on Jul 27, 2010
Anonymous
  • 143 Answers
SOURCE: Craftman Garaged Door Unit Stopped Working
This sounds like you will have to replace the logic board. Whether you repair or replace get a surge protector 900 joules or higher unless you want it to happen again. You can get replacement parts at searspartsdirect.com. Thanks BB
Posted on Sep 03, 2010
Andrew
  • 103 Answers
SOURCE: I have a Manitowoc QD0212A
Try cleaning the radiator for the ice box compressor it could be tripping it's thermal overload switch, if that doesn't work check to see if the termostat setting is in the range for the compressor to turn on when the ice starts melting.
Posted on Jun 29, 2011
How do I fix my Taylor Soft Serve Ice Cream Machine? It often trips the breaker even though the machine is switched off.
Sounds like a power supply problem\ mis wire. Receptacles or cord wiring don't match. Ground wiring wrong..This unit has two supply cords. Possible wiring cut and hitting metal .somewhere in supply. Hire a professional, could be dangerous.
Jun 30, 2018 | Washing Machines
The machine will make a couple of cycles of ice then stop. If i turn it off to clean then turn it on it will work for a few more times but then stop again. Any ideas?
Sounds like the bin switch. If it stays in the open position then the machine thinks it is full of ice and go to automatic shut down.
Sep 19, 2015 | Manitowoc Ice Machine QD-0212A Air Cooled...
Manitowoc q270 ice machine won't make ice .. It doednt sound like its turned on?
unplug and plug back in or turn breaker of and on to reboot the computer
Mar 07, 2014 | Kitchen Appliances - Others
My ice machine manitowoc q 132a starts up stops after few seconds while water pump start
There is a high pressure switch that stops the unit running if a fan fails or the condenser is clogged. Next time you start the ice machine, watch the bottom led on the pcb. It will tell you if there is a fault. Meantime, reset the hp switch and clean the condenser thoroughly.
Sep 06, 2012 | Refrigerators
I have a Manitowoc QD0212A 120v. It makes ice, but after the bin gets full, it appears that the compressor does not run to cool the ice box. Is there some type of relay or solenoid that could be bad?
Jun 29, 2011 | Manitowoc - QD-0212A/115-1
Ice machine starts on harvest mode and will not go on to production
you will have to find the main board unplug the connector for about a mintue plug back in. This should reset unit
Aug 05, 2009 | Manitowoc MAN-CVD2075 Condenser Unit...
A/c outside not working
The buzzing noise is your contactor drawing in from your thermostat. The fan part of your unit is on a different circuit from your outside A\C unit. Your thermostat is the conductor of the orchestra tying ths units together. It may well be that your A\C circuit breaker has tripped, if it has there is a reason for it's tripping. Resetting the breaker by turning it off then on may get your unit running, but a technician needs to ascertain why it tripped. Or it could be a bad contact switch inside the outside unit not letting enough electricity through the switch. More than likely the first issue. Good Luck
Jul 15, 2009 | Goodman CKL36AR36 Air Conditioner
Manitowoc 210 ice maker
The thickness control (Im not sure if its like the bigger models) isa plastic piece that has 1 or 2 metal prongs that as the ise is frozen to the evap plate the water trickels closer to these probes. eventually commin gin to contact with the probe and allowing the board to "see" that the ise is ready for harvest. Perhaps this is set too close?
Or the machine may need a good cleaning. DO NOT USE LIMEAWAY on manitowoc. It has a nickle coating on the evap plate and the cleaner has to have inhibitors in it to keep the nickle plating from flaking off.
From your genmeral information these are a general idea of the 1st 2 things that can cause your problem.
Please ratem me as high as you can and let me know if you have tried anything and the results or if you have more information to add.
Mar 29, 2009 | Manitowoc Koolaire Undercounter Freezer...
Kitchen Appliances - Others Logo
116 people viewed this question
Top Manitowoc Kitchen Appliances - Others Experts
Marvin
Marvin
Dennis
john h
Are you a Manitowoc Kitchen Appliances - Other Expert? Answer questions, earn points and help others
