Question about Proscan Televison & Video
Proscan tv won't stay on - Proscan Televison & Video
Posted by Tina Haynes-Wallace on
Proscan tv
There should be a short circuit to any of its internal board. If power supply switches on, and TV do not work, check the main digital board for fault. Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and five hundred posts. All are related to television and other domestic electronic equipment service help.
May 20, 2013 | Proscan 32LB30QD 32 in. LCD TV
My tv. proscan mod. ps50700 won`t turn on
The PS50700 uses the 195 series chassis. The most common cause of the set not starting up is a shorted flyback (high voltage) transformer. Sometimes a shorted flyback will also cause the horizontal output transistor to short too. These parts need to be tested and/or replaced by a tech familiar with the RCA 195 chassis.
Aug 17, 2007 | Proscan PS65000 65" Rear Projection...
My proscan won't stay on until it gets warm,
it was a common problem with an lcd tv, usually a leak or bulged capacitors in the power supply board will be the caused.
Nov 01, 2012 | Proscan Televison & Video
Proscan 40lc45s won't stay on
Try changing the input device to something you are sure, works such as a DVD player. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Aug 01, 2012 | Proscan 40LC45S 40 in. LCD TV
Proscan 32LA30Q won't power on
It appears to be a 32 inch.
Some questions:
Does power light come on and if so what color when set is off?
Were you having any problem before where you had to turn set on several times to get it to come on and stay on?
I am here to help you.
Mar 14, 2012 | Proscan 32LA30Q Television
Proscan 42LA45H 42 in. LCD TV won't turn on, no red led when plugged
The power supply is the most likliest cause of the issue. You can get replacement power supply from www.tvcircuitboards.com
Mar 02, 2012 | Proscan 42LA45H 42 in. LCD TV
Tv problem
what chassis is in your set,look at the rear panel for model and chasis type to help to diagnose fault
Televison & Video Logo
Top Proscan Televison & Video Experts
matt martin
matt martin
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
