Question about Vizio Televison & Video
Vizio M550VSE (Y01002G model main board model) bricked, vizio logo for a second then turns off. Any way I can use the Y01001G main board to fix it?
    Top Expert:
  • Vizio Master
  • 76,204 Answers
Contact any service technician.
Posted on Dec 06, 2019
6ya staff
SOURCE:
Anonymous
  • 56 Answers
SOURCE: my vizio vx32l will not turn on. vizio logo will
The main board has failed. Replace the main board will fix the problem.
By the way, where did you buy the TV? If you have bought it from Costco then try to give them a call to see if it still under warranty.
Hope this will help.
Posted on Feb 19, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: 42" Vizio - no picture no sound
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
Posted on May 04, 2009
nicknovikov
Nick Novikov
  • 101 Answers
SOURCE: how much do amain board cost on a 42 inch vizio tv
shopjimmy.com.check this site.
Posted on Oct 05, 2009
alteans
  • 27 Answers
SOURCE: Vizio VX42L LCD TV died?
it is the power supply. in the given scenario like yours, the PSU is the suspect in 90% of the cases.
Posted on Apr 09, 2010
Testimonial: "alteans is very helpful."
ginko
Ginko
  • 19396 Answers
SOURCE: VIZIO GV42LHDTV Got TV after
Hi.
If the TV does not start with the new audio board, and if it does start with the old one, then the audio board that you recently purchased is defective.
About the board : 0500-0507-0230; that is the power board (PSU). If you could see the Vizio logo, that means that TV started, and that the power board was OK without need for testing. When the power board is defective, either the TV does not give any sign of life, or the TV goes in standby mode from start and does not wake up. In that case the led stays blinking to warn you that there is an incorrect voltage from PSU.
If the TV is freezing with Vizio logo, that means that at most the faulty part is the main board.
Also, you say that there is no backlight. No backlight means that the screen is completely dark. If there is no backlight you won't be able to see the logo or any other picture.If there is no backlight, then the problem is usually the inverter.
Here a brief article summarizing how to test PSU and inverter: How to test an LCD TV.
Here all parts for this model:GV42LHDTV.
Regard.
Ginko.
Posted on Feb 11, 2011
How do I fix a 55" Vizio smart TV
Fuses but try one of those neiborhood fixers their cheaper for that piece
Mar 20, 2016 | Vizio 55" Class LED 1080p 120Hz HDTV,2.49"...
Vizio 55 inch TV LED model #M550VSE starts up showing icon then turns off after a few seconds. If I keep turning it on the icon comes up & and then locks up. Have to unplug it at this point.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 07, 2016 | Vizio Televison & Video
How do I fix problem with Vizio m550vse LED TV? Flashlight test reveals picture and no back lights are visible.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Nov 20, 2015 | Vizio 55" Class LED 1080p 120Hz HDTV,2.49"...
Have vizio m550vse the power will turn off
Make sure all the connections are securely attached. Perform any software updates. If the TV is randomly turning off it sounds like a problem with the power board in the TV. Check you warranty limits asap.
Feb 13, 2015 | Vizio 55" Class LED 1080p 120Hz HDTV,2.49"...
I TURN ON MY VIZIO MODEL M550VSE FROM THE REMOTE CONTROL, IT JUST SHOWS THE VIZIO LOGO AND THEN IT SHUT OFF BY ITSELF
This sounds like an EEPROM issue. it has gotten corrupted and needs to be "re-flashed".
May 03, 2014 | Televison & Video
VT420M no sound or picture and turns off by itself
this sounds like a main board failure but a defective power supply can mimic some symptoms of a bad main board. I would recommend you get a diagnosis done on the set. If I was a betting man, I'd guess the main board
May 27, 2013 | Vizio Televison & Video
My vizio e371vl will not power on but the orange vizio stays on
The main board is usually at fault in a vizio when the logo doesnt turn white which indicates the main board isnt processing the power on command. You can get free technical assistance to troubleshoot that model by contacting the guys at www.tvrepairworld.com
Mar 21, 2012 | Vizio Televison & Video
My vizio vx32l will not turn on. vizio logo will
Feb 18, 2009 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
23 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Jerry Greenberg
Jerry Greenberg
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
