Question about Ricoh Office Equipment & Supplies
Estou com problema na ricoh mp 7001, acusando sc 868-1, podem ajudar?
Posted by ANTONIO ROBERTO... on
1 Related Answer
vinay229229
Vinaya Kumar Kuchipudi
  • 1121 Answers
SOURCE: estou com o erro 47:01
star wheel motor error,replace it, most of the cases star wheel unit gear penion broken observed.
Posted on Feb 02, 2012
Minha Ricoh SPC 430DN deu erro SC 563, podem me ajudar. Sou do Rio de Janeiro - Brazil
  • Code: 563
  • Description: Pressure roller overheat 3 (software error)
    The detected fusing roller temperature stays at 230°C or more for 1 second.
  • Causes: • Defective PSU • Defective BCU
  • Remedy: 1. Replace the pressure roller thermistor (center). 2. Replace the PSU. 3. Replace the BCU.
Ricoh Aficio SPC430DN Error Codes List page 11 from 17
Esto dice que es posible que el Photo Conductor Unit Copier Drum es malo o el Color Copier BCU Engine Control Board es malo.
Jan 26, 2018 | Ricoh Office Equipment & Supplies
I know how to replace it But Where can I find the waste toner bottle in Aficio MP 8001
In the manual (free download) here: Aficio MP 6001 6001 SP 7001 7001 SP 8001 8001 SP 9001 9001 SP download page I can't find any entry about waste toner, only the waste toner can't be reused, but no entry where to find the container. Sorry
Feb 09, 2015 | Ricoh Aficio Mp 8001 Copier - 910k Copies...
Error sc 204 mp9001
PROBLEMA NA RICOH MP9001 SC 204
Jan 28, 2014 | Office Equipment & Supplies
TENHO UMA RICOH 161 E DEU O CODIGO SC 819
Isso é um erro de firmware.
Existe uma actualização que corrige isso. Se tiveres acesso a descarregar os firmwares e se souberes como fazer... O teu problema está resolvido.
Contudo aconselho que ligues com a assistencia tecnica. Contacta com a Ricoh portugal e eles enviam-te um tecnico que saberá fazer isso.
Boa sorte.
Mar 01, 2011 | Ricoh Aficio MP 161 Black and White Copier
Olá.. Estou com problema de
This site is nearly perfect and they were recommended highly in the cell phone forums.
http://www.unlock-zone.com
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Jan 04, 2011 | Nokia 2220 Cell Phone
Laser aficio 2045 (erro322)
ola ha a possibilidade de voce desmontar a LD INIT e limpar o LED do laser e os espelhos que ficam dentro do laser.
e um pouco trabalhoso mas da certo pois o toner derrama dentro do laser e ele nao consegue mais sincronizar.
precisa retirar 6 soldas das tres pernas dos 2 leds e retirar os parafusos.
May 10, 2009 | Ricoh Aficio 1035 Copier
Open Questions:
32 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
