The food is slowly starting to melt. Please help.
SOURCE: frididare upright freezer
it might have an insulation problem from the factory. or it could have a door seal problem. if it is under warranty i would use it because this problem will will lead to more problem in the future.
SOURCE: door gasket for Kenmore upright freezer model 2539239712
Go to sears parts direct website. It's part #3206261 and is in stock, $93.07. Good Luck! countrycurt0
SOURCE: Kelvinator Single Door Hardening Cabinet Flash Freezer fan
If the fan motor shaft is smooth with 1 flat spot the hub on the blade probably has a hex set screw that can be tightned with an allen wrench. If the fan motor shaft is threaded there should be a nut holding the blade on. Also yur motor bearings could be going bad causing vibration which damages the fan blade.
Testimonial: "the bearings going out would explain why the problem happens with increasing frequency. Thanks."
Control board is miscommunicating with the rest of your unit. Contact a professional.
