Open cpu cabinet.
Then refix RAM memory.
Pull processor fan and then processor remove dust from all parts and circuit.
Reattach both processor and its fan.
then check if still face same issue.
Then pull cmos cell from motherbord.
Change RAM memory slot module .
Remove pic cards from PCI slot.
Reattch ATX power connector from smps to motherbord.
Then check.
If still face same problem then your RAM has need to be replaced.
Let me know if you need more assistanse.
Thanks.
Testimonial: "Ram prob. It wasn't pushed in all the way. Also some wires had to be pushed in all the way. "
1)there is a mismatch ram , not a working ram ,or ram slot faulty.
2) go into bios see settings for temperature and voltage and rpm for fans.
one of them has triggered a beep alarm. usually its the temperature of processor
Testimonial: "It was the ram. I didn't push the ram in 100% to make the sides click on its own. D#@n I ****."
