Question about Cycling
I have a 290c stationary bike, and cannot read the screen, what can i do to get it fixed
Posted by Stanley Watts on
The screen on the schwinn stationary bike is not responding
Check batteries first. Is this a touch screen? Was water or a drink involved? Check connections to weight/wheel sensor also.
Mar 17, 2018 | Schwinn Cycling
How to fix my stationary bike after the wrong volt adapter was used
You have probably permanently damaged the electronics.
Does it work with batteries?
Jun 20, 2016 | Golds Gym Gold""s Gym Power Spin...
Where do I plug in ac adapter
There should be a power jack on the unit, sometimes on the console, but also check the lower front, and lower rear of unit. Exercise equipment service Treadmills Ellipticals and Bikes Parts Assembly...
May 22, 2015 | Golds Gym Powerspin 290C Upright Bike
What is a stationary exercise bike?
A stationarybike has basically the parts of a regular bike but it's stationary - it doesn't move. It's apiece of equipment used for exercise rather than transportation.
Jul 30, 2012 | Exercise & Fitness
How do i change the battery vitamaster 62c Stationary Bike
Simply pull the indicator module straight up out of its plastic holder. No screws are attached. With a thin flat screwdriver pry open the bottom off the module. Insert 2 AAA batteries. Reassemble.
Oct 28, 2010 | Kettler Exercise Bike EX1 Stationary Bike
New black ink cartridge won't print for Brother MFC-290C
run software cleaning function for the heads and run the alignment, make sure that you move all the stickers from the cartridges and the vent hole is clear, clean the inside housing from any dry ink...let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Sep 20, 2009 | Brother MFC-290C Printer
Cycling Logo
122 people viewed this question
Top Cycling Experts
Marvin
Marvin
Moderator Canada
Moderator Canada
Tom Chichester
Are you a Cycling Expert? Answer questions, earn points and help others
