Question about Electrical Supplies
Generator electronics - Electrical Supplies
Posted by John Michels on
  • Carl Rock
    Carl Rock Dec 04, 2019
    Is there a question?
Generator burning my electronics up
take you generator in and have the output tested for correct voltage and sine wave configuration
electronics rely on a perfect sine wave ac current as a manufactured sine wave affects electronic components such as capacitors, transistors and diodes
generator sets that run an alternator ( not an inverter ) have a pure sine wave and have less affect on electronics.
go google and type in search headings like ---sine wave, inverter sine wave, sine wave affects on electronics, alternator operation and inverter operations and then you may get a pointer as to why your inverter gen set is affecting your electronics
Jul 23, 2016 | Honda EU3000iS Inverter Generator
What is a pilot generator
Simply put, a pilot generator is a thermopile that generates millivolt power to operate a gas valve.
However, on your convection oven, yours operates on an electronic spark, which is generated by an electronic ignition control module.
Jul 29, 2014 | Vulcan SG4D Gas Single Oven
Generator vs mains power
Sometimes power is not clean enough for electronics. Other times the starting current is too high. You maybe able to make it work through some sort of isolating transformer or choke to clean up the power. Look into those suggestions. Also have you tried not plugging the machine in until the generator is up and running. The startup might be messing with the electronics.
Oct 29, 2013 | Indesit Washing Machines
Hayward Electronic chlorine generator bond to Jacuzzi magnum 1000
when i done mine i cut the pipe and glued another connector in to the pipe that goes to the jets ,
Apr 10, 2012 | Pool & Spa
Heart Freedom 20 will not default to generator power.
First of all it is possible that the is no power going into the inverter,trace the input source to see if the connection from the generator is ok. check the fuse if it is broken if not, the contactor or switching relay in the inverter is bad
Apr 06, 2010 | Xantrex Technology Heart Freedom 20 12...
There is problem with my cummins generator the is
check fuel filter it may be only getting enough fuel to run up to so many rpm
Feb 10, 2010 | OTC 7471A CUMMINS DIESEL ENGINE BARRING...
Dayton 3W351 generator doesn't generate. Runs fine but no AC output.
The reasons for the generator dose not generate electricity are as follows:
1, the magnetic pole of the generator loses magnetism;
2, the excitation circuit component is damaged or the circuit is broken, short circuit or grounding phenomenon;
3, the exciter brush has bad contact with commutator or the brush frame pressure is insufficient;
4, wrong connection of excitation winding, opposite polarity;
5, poor contact between generator brush and sliding ring, or insufficient brush pressure;
6, broken circuit of generator stator winding or rotor winding;
7, loosening of generator lead wire or poor contact between switch and wire; Fuses, etc.
Jan 14, 2010 | Electronics - Others
Generator Wattage
both sizes will handle that stuff as long as generator maintains a constant rpm. otherwise you run risk of low voltage or voltage spikes which cpu will not handle for very long
Dec 19, 2008 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
85 people viewed this question
Top Electrical Supplies Experts
john h
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
