Question about Sylvania Televison & Video
SOURCE: Sylvania vcr/dvd installation
!st) The antenna INPUT::RF (black wire usually from "cable TV", "Dish TV", even ANTENNA air wave reception,etc.) into INPUT of VCR\DVD, OUTPUT of VCR\DVD to TV RF input.
2nd) If you have INPUT\OUTPUT to what are called " RCA " jacks on your TV, on the front or on the back, then any & all output jacks from VCR\DVD goes to INPUT\OUTPUT of the TV.
In other words:: output of audio on VHS\DVD to input of audio on TV( RCA jacks). Output of video on VHS\DVD to input of video (RCA jacks)
Hope this helps
Posted on Aug 16, 2008
SOURCE: i need a remote code
have the same problem. I have Chunghop Universal remote RM88E but unable to find code for ORBIT DVD player
Posted on Nov 12, 2008
SOURCE: open/close button for DVD does not work on my
On most dvd players there is a little hole that is about he size of the end of a paper clip. A wheel is behind that hole, try using a paper clip or something similar in size and rotate the wheel, try both directions. If there is no hole under the tray just look under the tray.
Posted on Feb 20, 2009
SOURCE: i need the remote code for a Sylvania DV220SL8
You can download the remote codes and conditioning instructions from
http://remotes.com/remotes/documents/JVC/RM-C18G.pdf
Please rate this solutiion. Thanks.
Posted on Oct 15, 2009
SOURCE: my sylvania dv220sl8 won't retract dvd. any
1.you could unplug the unit for 30 seconds and then plug it in again.
2. if there is a pen hole in the front you will need a paper clip to insert carefully and then the door will release.
3. If you can remover the cabinet cover you can go in to the units drive and rotate the gear that ejects the transfer table for the DVD and retrieve your disk.
Posted on Mar 13, 2010
Feb 28, 2011 | Sylvania DV220SL8 DVD Player/VCR
Feb 25, 2011 | Sylvania DV220SL8 DVD Player/VCR
Aug 11, 2010 | Sylvania DV220SL8 DVD Player/VCR
Jan 09, 2010 | Sylvania DV220SL8 DVD Player/VCR
Mar 23, 2009 | Sylvania DV220SL8 DVD Player/VCR
May 17, 2008 | Sylvania DV220SL8 DVD Player/VCR
Dec 24, 2007 | Sylvania (SRDD495) DVD Player/VCR
