Question about Lands Phones
How do you store a name and number on a spirit 410 corded phone
Posted by rod burrows on
4 Related Answers
Anonymous
  • 47 Answers
SOURCE: How to add stored phone numbers. I lost my manual.
From the standby screen, press Menu.
Scroll to and select Address Book.
Scroll to and select Contact List.
Scroll to desired contact, press Options
Scroll to and select Edit
Edit the desired fields, press Save
Posted on Feb 23, 2008
Brian LaDuca
  • 149 Answers
SOURCE: re: storing contacts name/number
feature redial dial 00-19 for the memory location than dial a 1 than dial 9 and the full phone number than press feature to save it. If you have softkeys at the top of the phone(display) hit sta or sys to see the number you stored than pickup the receiver or hit speaker to dial the number.
Posted on Jan 02, 2009
Anonymous
  • 9 Answers
SOURCE: Changing Names on Extention Numbers from Main Phone
program,**,004,enter,(type in name using number keypad)enter, end.
Posted on Jan 11, 2009
Anonymous
  • 39 Answers
SOURCE: lost the manual how do I store phone numbers
Press STORE button, LOCATION? shows in display, press the memory location (0 to 9 or quick buttons A to C) then press STORE button again. Dial the number you wish to store and then press STORE again. Use the number keys to enter the name of the person you have just stored and press STORE again. I hope this was useful.
Posted on May 13, 2010
Doro 410S. I removed the battery so I could check serial number. Replaced battery and now it will not switch on. Battery is fully charged, Please help.
Remove the battery and clean the battery contacts with methylated spirits and the battery contacts in the cell phone.Make sure the battery is inserted correctly with the camera contacts.
Feb 01, 2013 | Doro PhoneEasy 410 Cell Phone
How to store numbers using panasonic KX-T7630
Hello Jd,
For storing numbers in panasonic KX-T7630
While on-hook Enter phone number(max. 32 digits). AUTO DIALSTORE OR Press STORE or ENTER. Enter name(max. 20 characters). AUTO DIAL Store or Pres STORE or ENTER.Press Exit or Pause.
Aug 18, 2011 | Panasonic KX-T7630 Corded Phone
Lost the manual how do I store phone numbers
May 13, 2010 | General Electric 29581GE1 1-Line Corded...
Jan 09, 2009 | Panasonic KX-T7630 Corded Phone
Editing Directory in a Merdian 9156 Phone
There is a directory button on your Meridian-press this button and press the down arrow key until the name is displayed in the display window and press your left arrow key to change the name and number after making the correction press your save button to store.  I hope this helps.
Nov 26, 2008 | Meridian 9516 Corded phone
NEC Dterm DTP 16D-1 How to store name to station number?
you need to get into program mode to change names. You also need to know what type of system it is. ldtsnj.com
Oct 15, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Re: storing contacts name/number
Sep 04, 2008 | NEC DTU 8D-2 Corded Phone
Numbers but no names
It's possible that the listing doesn't have a name. I know on my phone, that's the case. There may be a setting I'm unaware of though. Good luck!
Mar 25, 2008 | Panasonic KX-T7731 Corded Phone
Programming GE corded speakerphone
I fixed this just now on my phone, while seeking a solution here.
- Do not do what you'd think... putting the phone and name info first. It looks like it will take this info but it won't. That's where the frustration comes from.
- Dial the PHONE# FIRST.
- THEN click STORE.
- Then click the location (A-C or 0-8... save 9 for 911 if you don't have a red emergency key).
- Then click STORE again.
- Then type in the phone number again... this works, though there's probably a way to do it w.o putting in the number twice... but since it works, don't sneer at the free advice :) LOL.
- Then click Store
- Then type in the NAME
- Then Store.
Done. Repeat for other names/numbers. Now that you have it down, you can figure out how to do this without entering the phone number twice... but since I have a busy day, I'm just doing it this way.
Best wishes!
Oct 03, 2007 | GE Corded Phone
Lands Phones Logo
95 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
