Question about Sony Televison & Video
My sony lcd klv-52v550a 52 inch got a problem blinking 2 times. any solutions?
    Problem Solver:
  • 9 Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Sony Bravia KLV-40U100M-screen is distorted, overlay or various vertical lines
The resolution on this was to check the surge protector the television was plugged into. Once we unplugged and plugged into another surge protector, the screen went back to normal and the appearance was great. We believe this was due to one of the resistors within the surge protector may have become faulty.
Posted on Oct 08, 2008
Arjun Komath
  • 1170 Answers
SOURCE: Sony LCD (Model no. KLV-26V300A), standby light
Good day.
Blinks in the indicator signifies malfunction particularly in the horizontal and vertical sections. It is sometimes caused by loose connections due to wear and tear.
If parts would be available, then there would be no such thing as obsolete boards. You can request your technician to have the degree of repair be evaluated first to determine if the expenses would justify its existence.
Your respose is highly appreciated.
Regards,
Arjun
Posted on Jun 13, 2009
Dennis
  • 4 Answers
SOURCE: i have a old 52 inch sony rear projection tv turs on shows picture but picture blinks on and off
unplug the tv for about 5 minutes then plug it back in
Posted on Mar 31, 2012
SD Tech
SD Tech
  • 14553 Answers
SOURCE: Sony Bravia KLV-40S200A LCD TV standby indicator blinks 5 times
Here is a link to the service manual--
http://www.scribd.com/doc/46056922/KLV-23S200A-and-Other
Page 11 explains the error codes--unless you are a tech with a meter etc it will be a shop repair.
A lot of good info including taking set apart correctly.
"abnormal power"
SD TECH
Posted on Jun 02, 2012
gopakumarg43
  • 76177 Answers
SOURCE: My klv-21sg2 sony LCD color tv red light blinks 1 second and off for 2 seconds
OCP ( Over Current Protection ) . Your TV need a thorough checkup. Contact any experienced service technician.
Posted on Sep 04, 2012
Sony bravia klv 24ex430 red light blinking 2 times?
KLV-24 EX430
RM-GA022
Troubleshooting
3-3. Standby Led Blinking
3-3-1. 2-times Led blinking
2 times Blinking
Check DC voltage at
JL6023
Is it 18V 19 5V?
Yes Change
- 19.5V? B*board
No
Take out adaptor
and test at adaptor Yes
output is it 18V - 19.5V?
Change
B*board
No
Change
adaptor this is flow chart for 2 blink
Aug 13, 2017 | Sony Televison & Video
Flash red power flash 5
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 21, 2015 | Sony KLV-52V550A 52 inch Multi-System Full...
Sony bravia klv40v300a lcd tv 6 time led bilink.what is the problem
It sound like it took a power surge. suggest you either have it serviced or replaced the tv itself. Frankly if it is not under warrenty then it is time to purchase a brand new tv.
Feb 20, 2015 | Sony KLV-40V300A Multi-System BRAVIA LCD...
What could be the problem with my sony bravia klv 40-bx420 lcd flashing red led 2 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Sidebar" will make surf easy.
Aug 11, 2014 | Sony KLV-40BX420 40 1080p Full HD Bravia...
Sony LCD KLV32BX35A 5x Blinking Problem.
When an LCD TV turns on for a little while, and then dies, problem usually capacitors or IC's in Power Supply section, specifically diode bridge in Inverter board, or T-Con timing board.
Jul 17, 2014 | Sony KLV-32BX300 32 inch Multi-System LCD...
Sony klv-42ex410 blink 6 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
May 09, 2014 | Sony 42 inch KLV-42EX410 Multi System LED...
Sony klv 26s550a red light blinking problem
Apr 08, 2013 | Sony KLV-26S550A 26 inch Multi-System HDTV...
Sep 04, 2012 | Sony WEGA KLV-21SG2 21 in. HDTV-Ready LCD...
"abnormal power"
SD TECH
Jun 02, 2012 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Televison & Video Logo
32 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
