Question about ASUS Computers & Internet
Need help with ASUS PB278Q power supply replacement
ASUS ADTVDF561EQBM Power Supply for PB278Q, but the board in my monitor is CF661EQBK ... is the first one a suitable replacement for my monitor?
  • ASUS Master
  • 5,415 Answers
As asus.com first, why not? they designed it.
did you lose the old one (no clues) or is burned out dead (not stated)
so if not lost, read the tag on it.
what is the DC volts watts is 60w.
but if its 12vdc buy pack that is 12vdc and 60w or more watts.
5 amps at 12vdc or more, amps.
the pray the connector matches, only ASUS knows this. for a fact.
why not ask Asus this, (from the horses mouth as we say)
Posted on Dec 03, 2019
    Top Expert:
  • ASUS Master
  • 65,425 Answers
ASK ASUS NOT FIXYA DA
6ya staff
SOURCE:
Benimur
Louie Role
  • 6966 Answers
SOURCE: AMD sempron power supply
I would venture that "shows winfast on monitor" indicates the type of Video Card that your PC is using. Thereafter it should go to POST showing the motherboard, BIOS, memory count and others.
Since as you posted, after Winfast nothing follows, I can only suspect that you have a motherboard problem or at least a BIOS corruption.
Please post back the brand and model of your computer or at least what motherboard.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 16, 2008
Matampong
Trevor Sauna
  • 153 Answers
SOURCE: monitor fuse keeps blowing
There is definately a shorted component that causes the fuse to blow. Nomaly the ceremic capacitors are the cause of the problem. Check to see if there is visiual dark or burnt ceremic caps with label sameting like this "SCK 083" near the fuse area and change it. Hope it helps,cheers.
Posted on Jan 22, 2009
bluegreenash
Gareth Cockram
  • 661 Answers
SOURCE: Replaced my power supply, now keyboard and monitor wont work.
this is so familiar.... sounds like you've toasted your mainboard....
this could have been caused by a power surge, or by overclocking, or just when your PSU blew (it may have spiked your board as the voltage regulators failed), definately sounds like your graphics card/on-board graphics may be toasted too.
unsure if you have lost your PS2 ports and your on-board USB ports as you have no graphics output.
is it an on-board graphics card, do you have a spare/old graphics card you can test your system with?
if you cannot get your graphics systems working then you will need to replace your mainboard,
Posted on May 26, 2009
Anonymous
  • 4 Answers
SOURCE: Need info on component 3071 on power supply board - burned up.
Its been a while since i worked on that power board. But I believe you are refering to the orange diode that runs into the single connector for the video board next to the power supply. I replaced mine with a 1n914 diode after replacing the 2200uf lytic cap and the tv fired right up.
Posted on Sep 11, 2009
Anonymous
SOURCE: Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
Posted on May 10, 2010
Have a asus vw246h monitor will turn on and show asus and no signel and then no screen and power light goes red
Have a asus vw246h monitor will turn on and show asus and no signel and then no screen and power light goes red? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
5E 0NC02 001 4H 0NC02 A01 ASUS 5E 0NC02 001 Power Supply Backlight...
Apr 07, 2013 | ASUS VW246H 24 inch LCD Monitor
Where to find new power supply board (EADP-86AF B) for ASUS PG221 monitor
Instead of replacing the whole board, look for bulging (top) or leaking (bottom) electrolytic capacitors. Usually the failure is one or more of these inexpensive components which you can order from Digi-key.com and have delivered next day.
Try to stick to the correct value (uF) but you can go over voltage. do NOT go under voltage. for instance you can replace a 1000uF 16V cap with a 1000uF 50V cap, but not with a 10V.
Jun 09, 2012 | ASUS PG221 22" TFT LCD Monitor
I'm getting a "e<" error
I'm getting a "e<" error? This trouble maybe power supply or inverter boards is defective.
Sep 08, 2011 | ASUS VW246H 24 inch LCD Monitor
Asus VW246H monitor has backlight problem. I hooked VGA up to laptop and the monitor turns on but then 2 seconds later it goes very dim. how do i change the backlight settings?
how do i change the backlight settings? This trouble maybe power supply or inverter boards is defective.
Mar 29, 2011 | ASUS VW246H 24 Widescreen LCD Monitor,...
New asus vw246H monitor. the volume only goes down. how do I bring it back up?
New asus vw246H monitor. the volume only goes down. how do I bring it back up? This trouble maybe power supply or inverter boards is defective.
Oct 30, 2010 | ASUS VK222U 22" Monitor
Monitor keeps shutting down . sometimes it shuts down very often like less than a minute, other times an hour or more. i need help, thank you.
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this help....
Jun 27, 2010 | LG 22" FLATRON LCD Monitor
Asus P5P800-Vm
This problem is either your power supply, the mother board or the processor, try using a different power supply first and see what happens. Take the processor out of the socket and take it to your local pc store and ask if they will test the processor for you, if all are ok then it is *********** board is at fault and will need to be replaced.
Feb 10, 2010 | ASUS P5P800-VM Motherboard
Had a power outage, acer monitor will not power up
Normally there is a fuse that can be replaced inside on the power supply board. The are usually "slow blow" fuses and need to be replaced by an equivalent fuse. Many monitors have a soft switch which is controlled by the main board that tells the relays to supply power from the power supply. The CMOS devices on these boards are very suceptible to static so ground your hand to the chassis before touching any boards. If the backlight is out but there is a faint image on the screen when you look at it closely then the inverter board or CFT tubes are suspect. BTW: watch the Power supply and inverter boards as the caps stay charged and could result in electrical shock. Good luck. Hope this helps.
Jan 03, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Computers & Internet Logo
15 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
