Question about Furniture
Danby dual wine cooler sending error code eec. What would cause this
Posted by Kathy Lewis on
5 Related Answers
Demy
Demy Vasquez
  • 20 Answers
SOURCE: danby wine cooler
Is it because your keypad not functioning, meaning does the number change when you press the arrow up or down? Or when you set it, (let's say 12 Cel.) it does not reach down to that temperature. Then it could be either it's a sealed system problem( leaking refrigerant or under charge if it's a new unit). Or it could be a control problem( electronic control or sensor)
Posted on Aug 01, 2007
Timothy Snead
  • 6 Answers
SOURCE: danby wine cooler repair
call Danby at 800 263 2629, you can order parts from them
Posted on May 27, 2008
mcnutt10
SOURCE: E4 Code
Between phone calls to danby and my neighbor, we fixed this problem. My E4 was on the left (lower chamber). If you have one on the right it is the upper chamber. The E4 is a defrost sensor that can be ordered from Danby's distributor (call Danby for the one in your area). The part and shipping were around $30.
If your E4 is on the left...
- remove the top shelves
- open the cover inside the cooler above the digital read outs (the top unscrews)
- inside is were the repacement sensor plugs in
- replace the one with the long cord
- run the sensor down the back to the lower chamber
- replace all covers and parts
If the E4 is on the right...
- look on the right hand wall for a black plastic grate, the sensor is under this grate
- replace the sensor (simple plug and play)
- replace the racks.
Please pass this on, it was a ***** to deal with Danby and I nearly trashed the cooler out of sheer frustration.
Posted on Jan 01, 2009
Anonymous
SOURCE: MC wine cooler MCWC44DZ error code e3
I had an E3 on the upper zone. This fix was simple. Unscrew the 2 screws for the middle tray. Pull tray out as far as you can. Check the wires in the back, those are the wires for the fans in the back. The connectors over time corrode, and break off... All I did was connected the 2 wires that had broken off of their connector directly to eachother. E3 went away and the cooler is working as it should now.in
Posted on Feb 17, 2010
jdesrosi101
jdesrosi101
SOURCE: Danby DWC283BLS Wine Cooler - Error message E3 & E4
E4 on danby designer wine cooler -
TEST your compressor: Cooler can be forced to operate and cool as a test.
Unplug unit from 115v receptacle.
Hold both temperature control buttons down.
Plug unit in 115v receptacle.
The cooler should start, but the thermostat will not stop the compressor. Now you got a freezer ! I do not know how to fix the E4 error yet.
Posted on May 13, 2012
Danby DWC2121BLS dual commpartment wine cooler is cooling normally but after 2 days aprox the temperature increase and beeping and flashing hi
If evaporator starts to freeze up the ice accumulated serves as an insulator and the temps go up. If you turn it off and let ice buildup melt the unit will work fine again until it refreezes.
Check if unit has a device to prevent ice build up. If so, it is not working. If warm moist air is entering the area of evaporator coil, that could also be causing the buildup.
Sep 26, 2016 | Danby Silhouette Dual Zone DWBC14BLS 13.90...
Wine cooler frost buildup
Some dual temperature wine coolers build up frost in the rear and top of the main compartment. Check the defrost timer, located either inside the main compartment near the light, or outside on the back of the wine cooler near the compressor. Look in the owner's manual for the correct settings for the defrost timer and adjust yours as needed. Make sure that you have the wine cooler in a spot where the outside temperature remains at or near room temperature to reduce frost buildup.
Aug 11, 2012 | Danby DWC283BLS Wine Cooler
Cannot get Danby Silhouette 166 dual wine cooler to change temperature. It stays at 70 (both upper and lower). Can you help. Just bought used brought it home and it won't cool.
I also just brought home a used Danby Silhouette 166-bottle wine fridge and it is not cooling. Did you have someone come look at yours and did you get it fixed?
Jul 13, 2011 | Danby Silhouette® DWC276BLS Wine Cooler
E4 Code
Dear moriquenda
welcome to fixya.
Did you try resetting the system by pulling the plug and waiting 5 minutes then restarting the wine cooler?This may solve you problem.
Danby expects customers to call service and does not imagine the rest of the world being able to utilize these codes.
Closed minded, Huh?
Please remember to leave a rating!
Huuum
Sep 28, 2008 | Danby DWC283BLS Wine Cooler
E7 Code
Dera grezni
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
Sounds like we need to try to reset the system!
Huuum At your service!
Lets try this,
With an error code.
This can reset the system if it is electronic!
Unplug the appliance and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Let me know how it works! Waiting for your reply!
Please remember to leave a rating when you are done!
Thank You huuum
Aug 20, 2008 | Danby DWC283BLS Wine Cooler
Danby Wine Cooler
If you are getting the E4 error code, try replacing the defrost sensor. The part might take forever to get to you, but we replaced the sensor on the wine cooler and it's working.
Jul 13, 2008 | Danby DWC513BLS Wine Cooler
Is the compressor running? I don't know this unit, but know that if you are too warm that is the first thing to check. In reading about another unit that had a different problem, it was mentioned that there is a ciruit board. If it has relays on it then these are the most likely culprit. They are either not making contact or staying in contact too long... sometimes just tapping each relay usually a black plastic component will cause it to work intermittently..Not sure if you can get these but call the company help line at 1-800-263-2629.
Jun 12, 2007 | Danby DWC283BLS Wine Cooler
Furniture Logo
96 people viewed this question
Top Furniture Experts
Tom Chichester
ray gallant
Are you a Furniture Expert? Answer questions, earn points and help others
