Question about The Optics
I changed out my battery in my range finder 400.Now the cross hair don’t want to show up . I know it old So is it a way to fix it or retire it
Posted by Robert Crochet on
5 Related Answers
Anonymous
SOURCE: need manual
What are you looking for in the manual? Maybe I can provide you some guidance from my manual.
Posted on Dec 21, 2008
Anonymous
  • 99 Answers
SOURCE: user manaul
http://www.bushnell.com/customer_service/manuals/rangefinders/20-0405_YP_400.pdf
Here is your Manual
If you do not have a PDF viewer, use
Foxit v3 build 1506 Free PDF Viewer
You can google it or i did for you this is the safest result i saw (its a freeware which means free software that is published and distributed from many sites ie no home site)
http://www.afterdawn.com/software/desktop_software/word_processing/foxit_pdf_reader.cfm
sry this assumes your running Windows. If not select the other OS options there are on the Foxit DL page GL
BTW please rate this post's usefullness
Posted on Apr 08, 2009
Anonymous
SOURCE: Bushnell Error codes
5/26/09 I spoke with Bushnell technical support today and they informed me that this error "Er6" means the unit can not repaired. They said this is one of their oldest models and that they don't even have parts for it anymore. They did offer to have me send the old unit into their Returns department in Kansas, and in return for sending them the old/broken unit, they will send me an offer to buy one of their new units at a highly discounted rate. Not a bad trade I guess.
Posted on May 27, 2009
agent91
Ned White
  • 2100 Answers
SOURCE: not a problem but need operation instruction for
I believe the second cross hair in your scope relates to an 18 inch dimension, or that of a deer. When you adj the wire to the body of a deer, it will be the distance, I'm not sure if you have to do the math, or the scope does it for you. Some scopes, you had to figure the hold over by the distance in the scope. others would be set to shoot at that distance. I would ave to look that one for you to be sure, but that is the idea. Hope this helps.
Posted on Mar 21, 2010
Anonymous
  • 27 Answers
SOURCE: Toshiba tp50h60 convergence
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Posted on Jun 14, 2010
U turn on depth finder. shows correct depth say 20 ft. then next u know showing 350ft. whats up with this?
Most depth finders have auto range and manual range. In auto range the transducer sounds the bottom and automaticly will switch the range. If the range is set to manual then its probably picking up the bottom upon start-up and going back to your manual range setting. I'd start there..
Good luck Aloha
Mar 22, 2018 | Boating
Battery replacement for golf buddy range finder
Ask on Internet , All cell types available , even advises you on different make & types, See if you can get old Battery out of Buddy Range Finder,
Mar 14, 2015 | GolfBuddy Golf Buddy - dsc-gb200 - Golf...
I have a tasco scope that has a range finder cross hairs in it and i was wondering if it was made for a 300 weatherby mag?
It will work for any rifle with an appropriate ring set. The range finder markings will fall at different ranges depending on the speed of your bullet. You will have to test or use a balistic calculator to find out these yardages.
Aug 09, 2013 | Tasco Optics
How to fix loose cross hair on david white transit
This is how I replaced the cross hairs on my David White 8080. Disassemble the tube piece nearest the eye. There is a small ring that holds the hairs, it has small marks on it to indicate where the hairs are to be attached. Use a large lighted magnifying glass. Remove the old hairs. Take some plastic model glue and using a toothpick, place a very small amount on the marks to anchor the new hairs. This type of glue will produce strings or "hairs" when beginning to dry if you use a toothpick to stretch them out. Place some drying glue (several seconds old out of the tube) on one of the marks, and pull the toothpick away (creating a hair) and pull it across the ring to the mark on the other side. Repeat for the second cross hair. With a little practice you can make some very nice cross hairs.
Dec 16, 2012 | David White 44 8834 1 22x Level Transit...
Can you still use your scope with broken horizontal cross hair for target practise? or do i need a new scope. i am using 30/06 rifle caliber at 100 yards.thanks, i just go to range twice a year.please...
I don't know what good it will be if the cross hairs are broken. You would be better off with iron sites. I would be looking at a new scope if I was you. Hope this helps.
Aug 06, 2010 | Optics
How do you use the range finder on your
You have to sight it in and then insert the ring for the specific ammunition and distance you are using. From then point on, you can dial in the distance and the cross hairs will be right on.
It isn't an actual range finder, it's a bullet drop compensator.
Mar 06, 2010 | NcStar Illuminated A.O. Rifle Scopes -...
Not a problem but need operation instruction for my scope.Its a tasco pronghorn 3x9x40 with adjustable yardage and has two elavation cross hairs,I have had it for many years and it works perfect,but I have...
Nov 11, 2009 | Tasco PH39X40D 3-9x40 Pronghorn Riflescope...
What is the center post for? and how do i use it? Thanks.
Not sure what you mean here, but here goes the best guess. The cross hairs have a step down to a finer line in the center, this is a sort of range finder. It is generally the size of a full grown deer at 100 yards. This is easy to see, if you get a full size deer target and hold at the center for a heart shot, try it I think this is what you want.
Mar 28, 2009 | Optics
Alignment problems
I'm not sure of which telescope and finder you have but I can give you some general instructions.
If your finder scope is is the type that is like a tiny telescope then you should see a set of cross hairs when you look into it. The goal is so that when the object is in the center of the cross hairs you should be able to find it in your telescope eyepiece.. To do this you need to align the finder scope,
I usually use a terrestrial object to do this. I use these because they don't move like stars do. You can choose road sign, a spot on a tree or a street light though that can disturb your night vision. Aim your finder at this object and center it in the finder. Check to see if it is in the eyepiece of your telescope. Use a low power eyepiece to give you a wider field. The low power eyepieces have higher numbers such as 25mm. If the object is not in your eyepiece find it and center it. Check your finder again. You need to adjust the finder so that the object is in the center of the cross hairs.
There are usually 1 to 3 thumb screws to adjust this. If there a three you go back and forth until it is centered. Check your eyepiece again to make sure the scope is still centered. You can use a higher power eyepiece (lower number) to refine this since it displays a narrower field. Just repeat the process.
Once this is done, you find the object in the sky in your finder and center it and it should be there in your eyepiece.
Clear skies!
-jodair
Mar 20, 2009 | Optics
Dec 29, 2008 | Toshiba TP50H60 50" Rear Projection...
Optics Logo
Top The Optics Experts
Paul Carew
Lawrence Oravetz
Vernon Taylor
Are you a The Optic Expert? Answer questions, earn points and help others
