Hi Tony-
I found this link to download a copy of the manual.
https://www.scoop.it/topic/jtzkncj/p/4100874528/2018/08/21/lite-on-lvw-1107hc1-manual
Hope this helps.
Posted on Dec 03, 2019
SOURCE: lite on dvd recorder lvw-5045
the point is what was it doing before it start to do what it is doing now.kindly explain then i will be able to help you
Posted on Feb 25, 2007
SOURCE: Lite On LVW 1107 HC1 DVD Recorder
Concerning a Liteon LVW-1107.
I have had this same problem many times up until I decided that my machine tends to prefer +R or +RW disks. I have had no problems with +R or +RW disks.
( If I record something on a +RW disk and decide I want to copy it to -Rs I will copy the files to the hard drive and then reburn to
-Rs using Nero.)
Once you have had the disk in the machine and it will not play for whatever reason you might just as well throw it away and get a new disk and start over.
You may need to pull the power cord and let the machine reset on occasion also.
Realize I am telling you what works for me.
It may or may not work for you.
I hope it does.
Posted on Feb 13, 2008
SOURCE: Lite On LVW-5045 DVD Recorder - won't record onto disc
Liteon lvw 5045 problem action failed.please consult our customer service for recovery. (error code: 0x810D0004)
Posted on May 10, 2008
SOURCE: the lite-on lvw-5115pn
Go to the setup screen;
scroll down to EXIT;
enter the numbers 2960;
a Region Menu screen will appear;
Select "(0)" or Region Free;
then press Setup Screen to exit.
The machine is now Region Free.
Posted on Oct 26, 2008
SOURCE: Lite-On LVW-5005 (DDW-813s)
I have same problem like you, but I have changed the DDW-813s to a new Lite-On DH-20A4P, it work perfectly, good as new. but you have to make some changes to fix it to the place
Posted on Aug 12, 2009
