Our skyworth model43E3300 has power & audio! The problem is no video display! What is the problem of our flat screen TV? Can u pls! Answer our questions? Thank you! More powers!
    Top Expert:
  • Televison & ... Master
  • 65,469 Answers
SADLY WE CAN NOT TEST IT TAKE IT TO A LOCAL REPAIR SHOP .
Posted on Dec 03, 2019
6ya staff
SOURCE:
AvioriX
ExpressFiX
  • 689 Answers
SOURCE: error message
Issue related stuck due to objects such as paper or plastic. make sure its clean and gears are moving.
Good luck
Posted on Jun 17, 2008
Anonymous
SOURCE: The screen doesn't display anything and the power button is flashing green
http://www.fixya.com/support/t661302-lcd_monitor_green_power_light_blinking
Check out my link, I repaired my flat screen monitor myself.
Posted on Jun 20, 2008
Anonymous
  • 11 Answers
SOURCE: missing power cord 12v
go to radio shack get a 12 volt 1500ma power supply with I belive it is a N% plug end but any how 800 ma to 1500 ma should run this and the plug end is standard plug with plus 12 volts on the inner side and negitive on the outer case side look at the back of the TV or the old power supply it sould have info on voltags and amprage, and the plug as to inner voltage and outer voltage on the plug any old time radio shack or electronics shop should be able to help you bring in the flat screen if need be as if you know its 12 volts then It wont mater weather you use a 1000ma 1500ma 12 volt ubnaversale power pack as the tv will only use the current needed so more MA is good the only concrn you have is the right mini barrle plug and the right side of +/- voltage on that mini plug being most use + voltage in the inner most circle and - 12 volts on thje outer
Posted on Jul 03, 2009
Anonymous
SOURCE: No Video but have Audio
your inverter board is probably bad
Posted on Aug 18, 2009
Anonymous
SOURCE: was watching tv all of sudden screen turned black, with audio...
i was watcing tv afeter a while i realized there is no picture but we have sound
Posted on Sep 29, 2009
Screen no turning on red light
Is audio output is OK? Provide more details.
May 22, 2013 | SNK Skyworth SLC1963A 19 in. LCD TV/DVD...
My skyworth 15.6in flat screen has been saying no signal
check the input selection on menu of tv, it may be trying to read dvd player without dvd inserted or another device connected to tv. also check to make sure cables are secure,. Most likely it is on wrong input.
Oct 17, 2010 | SNK Skyworth SLC1963A 19 in. LCD TV/DVD...
There`s picture but there`s no sound. how can I fix it? Thanks
try check the connection of the wires or try to check if you lock the mute button..
Sep 08, 2010 | Starlite Skyworth SLC1551AW 15 in. HD LCD...
I have a 15" skyworth tv my screen has been severely damaged can it be repaired?
Probably not economically worth fixing, you can buy a new one for less than $100.00?
Jun 01, 2010 | Starlite Skyworth SLC1551AW 15 in. HD LCD...
My computer screen has a big strip running down the middle, how can I fix?
looks like your screen has a bad lcd cable (internal), you should conatct Skyworth or take it into a local bestbuy or staples. Reply and Vote!
Mar 28, 2010 | Starlite Skyworth SLC1551AW 15 in. HD LCD...
I need a dc power cord for my skyworth tv..can't find one
just buy any 12VDC power supply with 5A rating and then just change the connector with the same size on type.
Jan 17, 2010 | Starlite Skyworth SLC1551AW 15 in. HD LCD...
My Skyworth LCD TV 32" doesn't turn on.The light in the on/off switch doesnt turn green.Pls help.
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 13, 2009 | Starlite Skyworth SLC1551AW 15 in. HD LCD...
Skyworth 32l08hr is no power
your tv power board is burn and is better change power board or take ur tv ur tech.person
May 12, 2009 | SNK Skyworth SLC1963A 19 in. LCD TV/DVD...
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
