Question about Canon Office Equipment & Supplies
I've have a Canon PC1060 copier for years but never used the two-sided copy feature and can't figure out how to get it to work--can you help me?
  • Canon Master
  • 10,749 Answers
Posted on Dec 09, 2019
6ya staff
SOURCE:
Anonymous
  • 7 Answers
SOURCE: CANON PC 20 COPIER
I think the plastic broke that held the spring, so you need to figure out where it broke and drill a new hole for the spring, and sounds like you need a new cartridge, GOOD LUCK!!!
Posted on Jan 24, 2008
Steve Archer
  • 148 Answers
SOURCE: How to remove the scanner unit on Canon PC1060
you sould not have to remove the scanner unit to clear a jam in the fuser
open all doors and remove anything marked green
remove the the cartridge assembly if it will come out
open the fuser section (usually a release that takes pressure off of the fuser rollers
remove the paper feed cartridge
you now should be able to follow the paper feed path from the time paper goes i until it comes out
if you are not sure of path take a piece of card stock and simulate it goig through feed ara
there are small microswitches/ poto eyes that sense paper lok for an small pieces also clean thes poto eyes with q tip and rubbign alcohol
reassemble
unlug from the wall then plug back in and turn on p roblem sould be solved
Posted on Jan 05, 2009
Anonymous
SOURCE: Lines on copies
The lines are caused by some debris that is on the platen (the glass where you normally place the copies). The usual culprit is white-out smudges from a copy that wasn't completely dried yet. When you make copies using the feeder, the roller passes the paper being copied over a little section of the platen (if you pull up the feeder "lid", it'll be on the right-hand side of the big glass... it might even be marked with 2 green arrow stickers, but if not, it's the part of the glass directly under the roller of the feeder). You can just take an alcohol wipe or soak a cotton ball with alcohol or windex and wipe down that strip of glass under the roller.
Posted on Mar 23, 2009
Anonymous
  • 15 Answers
SOURCE: Line appears on copies when using the automatic feeder.
You have a piece of dirt or whiteout on the scanner glass. When the paper is moving by, it creates a "Line" if the paper is sitting still on the glass, it may be a dot or it may even use a different glass alltogether for ADF vs Paltten scanning.
Posted on Jun 09, 2009
PATHAMPAD
MANZOOR AHAMED
  • 25 Answers
SOURCE: Printing double sided color copies.
CHANGE YOUR DUPLEX PAPER SELECTION MOTOR
Posted on Oct 31, 2009
Canon pc1060 making very dark copies
Make a copy with the lid open.
Is the scanning lamp illuminating?
If not, the lamp or fuse is blown or problem with supply voltage from lamp regulator pcb.
Sep 03, 2010 | Canon Office Equipment & Supplies
COPY PRINT OVERLAP AND DARK
need to replace the drum unit.
Jan 20, 2010 | Canon PC1061 Copier
Dirty copies on Canon PC1060
First replace drum cartridge
Nov 04, 2009 | Canon PC1061 Copier
PC1060 COPIER
Remove the drum unit,there are two clips that keep the drum and developer unit together make sure they are hooked in place.
Oct 18, 2008 | Canon PC-1060 Black and White Copier
Replacing fuser pc1610
Please let me know if there is a technical reference or service manual for the PC1060 (including Image Class D860) printers.
MXM450, Please let me know how to replace the fuser. I have spent an hour trying to get to the fuser but am not sure if it is from underneath the feeder assembly, or through the toner cartridge door.
Oct 04, 2008 | Canon PC1061 Copier
PC1060 canon copier
in your case you have to remove the fuser
I will try to guide you, most of the models are the same.
1-turn off machine and unplug
2-open the side door, you already know where the paper is it's most likely rolled up on a hot long roller, this is the fuser unit
3-with a phillips scredriver(star) remove 2-4 screws that hold the unit, it will have a plug most likely on the right hand side unplug
4-unit should slide out (unless there is a cover holding it
5- you can now see and work on the unit turning the gear by hand to remove the paper.
6-reverse the steps
Aug 12, 2008 | Office Equipment & Supplies
Canon PC1060
The fuser comes out the left side, not from the top of the copier.
Jun 20, 2008 | Canon PC1061 Copier
Book copying
try in spec. features under book separation or something like that
Oct 16, 2007 | Canon ImageRUNNER 3570 Copier/Printer
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
