Question about Fujitsu Televison & Video
No light. On my tv
My Fujitsu TV is not coming on no light
Posted by Neil Blake on
Lecia Linda
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
No power to monitor. Red light does not come on.
Hello The TV is completely dead no power indicator,nor standby light. Probable main fuse failure, but first make sure your AC feed is present, try another electrical fixture in the TV ac outlet you are using to make sure the outlet is alive. If this is not the case then check the main fuse(located inside the TV) not recommended if you are not qualified to work on electronic equipment. A blown AC fuse usually is an indicator of more serious problem further in the power chain(power supply/HV circuits, etc.)
1helpful
Fujitsu P42HHA30ES Plasma TV screen has stopped displaying
It sounds as though you have a fault on the Power supply, the fan doesn't not normally fail on this model. If you'd like your screen repaired, please call 0208 731 3432
15helpful
2answers
42 Fujitsu PDS4221W-H, no power
A user manual is available from this link:-
http://safemanuals.com/user-guide-instructions-owner-manual/FUJITSU/PLASMAVISION%20PDS4221-_E
Check for a hidden power switch under the lower left or right under corner of the screen, ensure it is ON (- not sure if this switch is fitted to your model, but it does exist on other Fujitsu models).
Fujitsu no longer support or manufacture plasma screen TVs - therefore no parts are available from them. [Fujitsu only serviced to board replacement level - very expensive].
The Fujitsu models (generally, after 4 or more years use) suffer from cracked solder joints on circuit boards (due thermal cycling stress).
See Fixya tips:-
"Fujitsu Plasma 42" random shutdown - continuous flashing red led".
Fujitsu plasma tv won't turn on
you have a bad power supply. Bring your tv to repair shop.
42" Fujitsu Plasma TV (About 10 yrs old)
You have not fully identified the model number of your unit, but
this is most likely caused by the Main Power pcb.
For models P42HHxxxxx and P42HCxxxxx see Fujitsu Service Bulletin on this problem. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
4helpful
Fujitsu Plasmavision PDS-4233
HI, I haHe a Fujitsu Plasma HDTV Model PDS4233. The TV won't power ON, When i turn on the master power button the light starts flashing a red light repeatedly. I also observed that the Fans power up for about three seconds immediatly after i press the master power button, after the three seconds the fans shut OFF and the light continues to blink.. I haven't observed the light to see if there is a pattern with the blinking..
Fujitsu plasma tv
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem. -see link below
Fujitsu 42" Plasma Display shuts off after 20 minutes
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
A similar service bulletin is probably available for your model. Request bulletin from Fujitsu '[email protected]'
Televison & Video Logo
Top Fujitsu Televison & Video Experts
Joaquim Martins
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
