Please advise the approx cost for installation of smoke alarm for 2 bedroom unit. Thank you
If you don't mind changing batteries every 6-12 months during the year then you can pick up these smoke alarms from any hardware or even discount store. The also come in blister packs (2 to 6 or more for value packs) Most will screw mount to attach to wall. You can also use self stick foam tape to 'stick it' anywhere. Try to put them in a high spot on wall or ceiling depending on the surface (crumbly textured surface won't stick well. It will have to be mounted with a screw) The higher locations will give you quicker response time but It's harder to get at without a step ladder. Lower units have slower response time as the smoke has to collect and lower to the point where the alarm is.
*** Note; you will need to check your fire code requirements for placement of alarms. (though once this minimal requirement is met there is no reason you can't add more in other locations for added coverage; like a large walk in closet, baby's room, laundry room, etc.)
* Getting back to your question, I'm guessing you have the updated required powered alarms or need to have a "Powered" fire alarm. The newer homes (well last 20 years is new to me) have low voltage power lines running from room to room where the alarms are placed. If you required to install this type of system then depending on the ceiling access (crawl space, lowered ceiling, etc.) and the need to run the wires "hidden" behind wall and ceiling will increase the installation time and labor costs. Electrician or authorized fire alarm technician will be needed. They should check your fire alarm requirements for you local, indicate locations for alarms, run wires, install and test. Check with several companies in your area and get several quotes. Check with Better Business Bureau for rating or complaints.
* With Smart ware being all the rage. It may be possible to use these "smart devices" to alert you to other situations besides just fire hazards. Break in, baby monitor, door ringer monitor, water (flooding), Carbon Monoxide, etc. But the alarm guy should be able to give you more options. Though I's still up to you how much you want to spend.
* Final; You check what the fire codes require. If they called you first then suspect a scam or a sales pitch to get you to buy something you don't require. You can always go with the 'stick on' alarms if that is allowed for your area. Call the fire Dept in your area. Those are the 'good guys' that want to keep you safe.
Aloha, ukeboy57
Jun 06, 2018 |
Home
