Question about Dirt Devil Vacuums
I have a dirt devil featherlite bagged vacuum that is not picking up? I checked the belt and the brush and they are both moving, but not picking up dirt?
Posted by Antoinette Bell on
3 Related Answers
Anonymous
  • 28 Answers
SOURCE: No suction, belt is good and turing brush
take off the bottom cover, and see if something is clogged. trace it all the way to the impeller
Posted on Apr 14, 2009
galati2k
PETE GALATI
  • 281 Answers
SOURCE: dirt devile featherlite vacuum pushes extremely hard on high pile carpeting
the dirt devil featherlight has a automatic height adjustment for carpet and bare floors.check the wheels and see if there is something wrapped up around the wheels
Posted on Apr 29, 2009
Billy Detlefsen
  • 159 Answers
SOURCE: The Dirt Devil Featherlite vacuum cleaner throws
You have a blocked vacuum hose take hose off and out side. Push the garden hose from one end to the other, this will push out the blockage
Posted on May 10, 2010
How to fix dirt devil featherlite carpet cleaner loss of suction?
Hello! Below are general trouble shooting steps for your Dirt Devil vacuum to restore suction.
1. Check the hoses for clogs.
2. Clean and replace your filters if needed.
3. Check that your brushes are still spinning, if not, replace your belt with the recommended belt for your vacuum.
Hope this helps!
Jul 10, 2014 | Dirt Devil Vacuums
Vacuum not picking up.
check the bag it might be full if so replace for a new one check the belt it might be broken if you can see the fan sometimes there is some broken parts that have to be replaced
Jun 08, 2010 | Dirt Devil M085540 Featherlite Deluxe...
It doesnt seem to be picking anything up
Check the hose...they plug up and then everything stops...
Here is a tip that I wrote after having the same issues with my Bissell...
Bissell Bagless Upright Vacuum2_bing.gif not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
May 20, 2010 | Dirt Devil Featherlite Deluxe Bagged...
Vacuum doesn't pick-up dirt
It's probably not picking up because the belt is worn and stretched. With a new belt it will pick up a lot better. Here is the belts you need:
Dirt Devil FeatherLite Belt
Apr 07, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Belt is intact but brush won't turn
Even though the belt is intact it can still be stretched or worn and will not turn the brush on the carpet. Here are the belts you need:
Dirt Devil Featherlite Belt
Apr 07, 2010 | Dirt Devil M085850 Featherlite Bagless...
Dirt devil will not pick up
That means that you need to replace the belt. Here is the belt you need:
Apr 06, 2010 | Dirt Devil Featherlite Bagless Vacuum...
I have a dirt devil featherlite plus and all of the sudden it started pushing hard and smells hot. I cleaned the roller, changed the bag, checked the belt. The belt is a little wore, but not bad.
If it is pushing hard then you still have a belt problem. It may not be broken but the belt is stretched out too long and will not turn the roller brush fast enough to make it push easy.
Nov 27, 2009 | Dirt Devil M085500 Featherlite Plus Bagged...
Apr 14, 2009 | Vacuums
Dirt Devil Featherlite not picking up
It sounds like you have a blockage somewhere. The brush roll will still gather material, but if the suction is insufficient, it will spit it back out eventually. Take the bag out and check at the connection for blockage. When you are sure it's clear, put in a new bag and turn the machine on. The bag should inflate rapidly. If it does not, check elswhere for blockage.
Jan 19, 2008 | Dirt Devil M088905 Vision Bagless Upright...
Vacuums Logo
100 people viewed this question
Top Dirt Devil Vacuums Experts
Tim Venetis
Randy Schumann
Randy Schumann
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
