Question about Golf
Why does my Electric 1999 Club Car golf cart hesitates whenever the accelerator is floored, if I let up just a little it goes on fine.
Posted by Charlie Beveridge on
5 Related Answers
weblord
William Nabaza
  • 507 Answers
SOURCE: need a club car golf cart service manual
generic suggestion
http://www.blockbustergolfcarts.com/index.asp?Category=260&PageAction=VIEWCATS
http://www.lvssales.com/store/product.php?productid=13300
Posted on Oct 18, 2008
Anonymous
  • 416 Answers
SOURCE: club car golf cart has clicking sound in rear
It sound like brake shoe pulsation. Most probably you need to check rear brakes.
Another reason I just assuming since I dont have the car model and Brand.
Also it might be that if you can here this noise 20 seconds after you start driving, and if the resistor coil got very hot, that the solenoid might be bad. You need to check it too and if the solenoid is too hot to touch it can be bad. In this case cart really will loose a lot of power in both forward and reverse.
If you dont have that it might be brakes.
Let me know how it will go
Good Luck
Posted on Dec 28, 2008
Anonymous
  • 239 Answers
SOURCE: Need a manual
dear sir/mam,
use this link and select the required file
http://www.google.co.in/search?hl=en&q=manual+for+a+1999+club+car+(Electric)+golf+cart&btnG=Google+Search&meta=
Posted on May 05, 2009
Anonymous
SOURCE: Electric Club Car golf cart has a full charge but will not move.
gulf cart will not move It has a full charge
Posted on Mar 22, 2010
golfcartman
  • 34 Answers
SOURCE: club car golf cart intermittent no spark
What you have is a bad ignitor. It is a small part located behind the RPM limiter. Getting to it is a little tricky but I will try to explain. On the front of the motor, you will find 2 10mm bolts holding a black object that is the RPM limiter. Take these two bolts out and you will find the silver part behind the black box. It will have one wire running to it. The reason it is intermittent, is that heat from the engine builds up and the heat causes it to be bad. When it cools down, it will go to running again. The part runs about $50-$70 . Replace and make sure the connection fits snugly and that the wire that was under one of the bolts goes back on.
Posted on Apr 22, 2010
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum
www.buggiesgonewild.com > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from www.buggiesgonewild.com
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Jan 24, 2016 | Golf
Find the year serial nimber A9649-548612 club car golf cart was manufactured
Since 1981 Club Car Golf Carts have positioned their serial numbers just under the glove box on the passengers side of the vehicle. The first two numbers (not letters) indicate the last two digits of the year of manufacture.
On Club Car Golf Carts prior to 1981, you can find the serial number by raising the seat and locating the aluminum, I-beam frame section closest to the batteries on the driver's side of the car. If the serial number plate has been removed, you can confirm it is a 1975-1980 model if it has two brake pedals and one accelerator pedal.
Oct 20, 2014 | Golf
Club car golf cart
Electric or gas
Oct 22, 2013 | Golf
Club electric golf carts
Resister coil pack....Look up Buggies Gone Wild. Tons of info.
Sep 08, 2013 | Golf
Club car brake light not working
2008 precedenmt golf cart dash light keep coming off an on
Mar 02, 2013 | Power Equipment Solutions 2002 Club Car DS...
Need a manual
dear sir/mam,
Apr 23, 2009 | Computers & Internet
Free wireing diagram on a 1987 DS Electric golf cart
I have 1987 club car golf cart. I need the battery wire diagram.
Jan 01, 2009 | Electronics - Others
Need a club car golf cart service manual
generic suggestion
Sep 30, 2008 | Computers & Internet
Golf Logo
118 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
