Question about Optics
I need a rifle shot tube for a red Ryder #111 model 40
Posted by Ronald youngs on
4 Related Answers
bigcass
Josh
  • 35 Answers
SOURCE: need bolt for Springfield model 120 single shot
Gun-Parts.com Carries it, but looks as though re currently out of stock.
But it looks as though Numrich has it. As well as an "Exploded" parts list for ya.
Park Number 103950A Price: $37.25
Hope this helps.
Posted on Oct 16, 2009
agent91
Ned White
  • 2100 Answers
SOURCE: Need information regarding my Jason Model 962 Rifle Scope
If you need info on sighting in a scope, go to my profile, I have it listed in my tips.
Posted on Feb 21, 2010
mash_jumbie
STEPHEN DOWNING
  • 138 Answers
SOURCE: How can I get a replacement part for my BB gun NO.
try this link it has all the info u need
http://www.daisyrepair.com/parts.htm
information
Bucky's Daisy Parts & Sales
Ron & Jenn Scalzo
1338 Hibiscus Drive
Cape Coral, FL 33909-5113
239-458-8787 ----[email protected]
Posted on Mar 05, 2010
t0ny_pars0ns
Tony Parsons
  • 6281 Answers
SOURCE: Where may I purchase a model 40 shot tube?
Anywhere that sells them, really (whatever it is) - choice is up to you.
Posted on Jun 27, 2017
Savage 220 bolt disassembly how to
Take a look at you tube quite a few videos
Dec 14, 2016 | Savage Arms Savage Model 11/111 Trophy...
Serial # range for marlin model 60 with 18 shot tube and last shot bolt hold open
On Marlin-branded Model 60 rifles, the first two digits of the serial number indicate the year of manufacture. For example, if the serial number starts with 18... The 18 is significant, for subtracting it from 2000 gives the date of manufacture for the rifle, 1982. Likewise, a serial number starting with 17 would be a rifle manufactured in 1983.
This method has not been uniformly followed. It is valid only from 1971 through 1999. Prior to 1971, the first two digits indicated the year of manufacture. For example, a rifle with a serial number starting with 70... would have been made in 1970. Starting in 2000, this same old method has returned; the first two digits once more indicate the year of manufacture directly, with no subtraction required.
Sep 17, 2016 | Marlin Model 60 .22 Cal Rifle
Daisy repair
My Red Ryder B B gun is jammed-I have shot and shot it still no bb willcome out
Jan 03, 2014 | Daisy Model Red Rider Rifle 1938 BB Guns...
After pumping up the rifle it had very little pressure
The piston seal has failed, or the pressure valve. Daisy manufactures in China now. If its a Red Ryder or other cheapie, then its a spring loaded gun and additional pumps do nothinga
Feb 18, 2011 | Daisy Toys
Where do i oil the gun
On all the Daisy BB rifles I've seen (and on the Model 111 I've had for almost 40 years), the oiling hole should be on the top of the barrel, with the words "Oil Here" stamped around the hole. Hope this helps.
Jul 14, 2009 | Daisy Toys
NEED THE COCKING HANDLE FOR RED RYDER AIR
Recommend an eBay or Google search or contact Daisy directly here:
https://www.daisy.com/contactus
Apr 09, 2009 | Daisy Toys
Daisy Red Ryder BB gun won't shoot
1) **** the gun and look through the hole in the top, half way down the barrel.
2) You should see a BB loaded into this area.
- if no bb is present and you can see a circular magnet, then it is not loading.
3) if the bb is present and does not exit the barrel when you fire the gun, then the bb is deformed and will require the rifle to be dissasembled and rodded through the back side, forcing the bad bb out of the way.
4) If no bb or magnet is present through the hole, call daisy for a replacement. This indicates the shot tube has moved and will no longer load.
Apr 05, 2009 | Toys
Optics Logo
93 people viewed this question
Top Optics Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Optic Expert? Answer questions, earn points and help others
