Set up model d55x-g1 - Computers & Internet
Posted by anthony longo on
How do i get free unlock code for g1 google phone
Dear,
  • 1. Side out the Keyboard / Open Left Hand side Notch to unlock Battery Panel.
  • 2. Insert TMobile SIM Card and Battery.
  • 3. Press MENU Button Constantly and Switch the Phone using Red Talk End / Power Button but do not Release the Menu Key.
  • 4. This will put on the Phone in Safe Mode.
  • 5. Press to Emergency Dial Button, Windows dial *#06# and this will show IMEI Number: note it down and also Recheck IMEI with Box.
  • 6. Give IMEI to Unlock Code Provider www.unlock-tmobileg1.com and get the Unlock Code.
  • 7. Now Return to main Screen and Press MENU Button this Will popup APN Button, Just Press it.
  • 8. Go to APN Setting. There will be so many APN already Preset. Again Press MENU Button this will show NEW APN Popup Button again Press.
  • 9. Remember to put Right MCC (Mobile Country Code), and MNC Mobile Network Code, G1 Matches SIM card Data of MCC / MNC with these Setting and then try to use that. Settings.
    All World MCC / MNC codes is available here:
    http://en.wikipedia.org/wiki/Mobile_network_code
  • 10. Now Switch off the Phone and Wait for Unlock codes.
  • 11. Insert the Non T-Mobile SIM Card which you intend to use it with G1 and switch G1 on. (Your SIM must have
    Data plan / GPRS Activated so G1 will able to contact google.com for Activation)
  • 12. HTC G1 will ask for Unlock Codes. Type unlock code carefully, typing wrong code thrice may make Phone Hardware Locked.
  • 13. Once Unlocked your GPRS / EDGE / 3G Data Service will be active as per APN Setting we did before.
  • 14. Type Google User name / Password in Signing Window and this will Activate the Unlock G1 Device on your SIM Card.
  • 15. Make other remaining Data Setting like MMS / Home Page / Port to Active other Data Service
Thanks
Sep 14, 2010 | HTC Google G1/Dream Cell Phone Black...
My g1 has a triangle with yellow exclamation mark
i had this problem when i got my g1. you need to hard reset and set up setting and everything all over again.
Jan 06, 2010 | HTC G1
G1 problems
you just need to use a friends sim card that has the g1 data plan and set up your gmail account and then when you put your sim card in the g1 wont ask you for the gmail account again thats what i did
Nov 15, 2009 | HTC Retractable Car Charger For Touch...
How do i reset my g1
  1. Power off the G1
  2. Hold Home Key + End key for 20 seconds or until you see a "triangle with an exclamation point and a picture of the G1"
  3. Open the keyboard and hit Alt+W
  4. Restored!
Oct 01, 2009 | HTC G1
How to set up voicemail on g1 phone
Well i am not an expert on phones but try these methods: 1) On your G1 phone dial your own mobile number on it (just in case your voice mail number that came on your phones doesn't help you plus sometimes it asks you for your password and dialing your own number doesn't ask you this or at least on my G1 it doesn't) and it may prompt you to set up your voice mail and from there just follow the directions from there. or 2) Gently take the sims card (that small white chip next to the battery)  out of the phone and if you have another /old phone ( T mobile phone if possible) and place the card in there and dial your own number again then see what happens. If you get the voicemail set up in another phone take the sims card and put it back in the G1 and have someone to call you but either turn off the phone or don't answer it so this will give you the chance to test your voicemail. I used to have a razor and i had set my voice mail up on that. It stayed on there since i used the same sims card. I hope this can help but again i am not an expert.
Mar 09, 2009 | HTC G1
G1 charge light is not on but the phone is charging
Had a similar problem on my HTC (same maker of the g1) touch diamond, the charge light/indicator would stay on even after i took the cable out.
It could be just lag. Try doing a soft reset, where ever the reset button is on the G1 (Inside the back case?) If that doesn't help do a hard reset which deletes all data/settings (other than your carriers settings, your phone will still work), you would have to look in your manual, as I dont have a G1.
Feb 27, 2009 | HTC G1
Bluetooth not accepting anything
Hi
I was trying to transfer some ringtones from old phone to G1 and facing the same problem.
And now somewhere from net I found the solution to my problem.
Although it could not be done by bluetooth, but my problem is solved now.
You can also try it. It may help you out.
> Transfer ringtones/music/photos from your phone to Desktop
> Connect G1 to Desktop by USB cable
> On the top of G1 screen it will show the icon of USB (connected)
> Scroll down from the icon and select 'copy files from computer'
> Select 'Mount'
> On desktop a massage will appear, click 'open folder & show files'.
> Copy & Paste files from computer to G1. Now your files are in G1
> If you want to set any song as ringtone press & hold that song, a menu will appear and you can select 'set as ringtone'
Dec 01, 2008 | HTC G1
G1 Tone Problems
Like most (if not all) phones. when setting a ringtone you can only select the song you want ! the only way to have a certain part of a song as your ringtone would be to use Audio editing software on a PC and then crop the song how you want. enabling you to have a ringtone of a certain part of the song.
hope this helps
Greenie UK
Oct 26, 2008 | HTC G1
Computers & Internet Logo
26 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
