Question about Royal Office Equipment & Supplies
How to remove type cassette from royal scriptor
2 Suggested Answers
6ya staff
SOURCE:
Mihali
Mitch Vass
  • 147 Answers
SOURCE: Royal Scriptor II typing symbols and not the letters!!! 87 yr old mom could have hit a random button typing. ^^ and many others - no letters?
Look for keyboard I OR II put it in I.
You are in a foreign language mode more than likely
Posted on Nov 09, 2017
How to program a royal 210DX register
how do I reset the GT on my Royal 210dx cash register?
Mar 22, 2014 | Royal 110 DX Cash Register
How to remove a cassette from a gravity games bike
that woul depend on what type of cassette it has but regardless of that either type requires a specialty tool to remove. the most common one is a chan wrench and the other is a custom socket fitting. for the chain wrench wrap it aeound the cassett so that when you apply tension you are spinning in the direction that locks the cassette, it takes a good amount of pressure to pull a cassette so if it doesnt happen easy dont be suprised. the socket tool does the same as the chain but instead fits on the inside of the cassette in the hub bearing. remove your skewer before trying either one of these things and if you dont already have the tool your probably noy qualified for the job at hand. take it from a bike tech w/out these tools you will not get it to come off w/out ruining it with home tools. most shops are pretty chill, if you just bring in the wheel and ask em to pop your cassette it takes 2 secs so they probably wont charge you and if they do their a ****** shop.
Jun 06, 2012 | Cycling
How do you remove the ink cartridge from a Royal Alpha 2001.
If memory is working there is a lever with a red end just to the R. of the ribbon, pull it toward you untill it stops the ribbon cassette should lift out.
DickyO
Mar 31, 2012 | Royal Office Equipment & Supplies
I have a Royal Signet 25 Typewriter that works fine, except that the type is uneven and some letters come out very light, others are fine. I think it may just need cleaned and adjusted, maybe? Any...
It might be a ribbon problem. take the ribbon cassette out and look at where it has been typed on. Do the characters overlap? If so, get a new one. Or the ribbon might be dried out. Is there an impression control? Set it on heavier print. If you have a different print wheel, try that too.
Feb 09, 2011 | Royal Office Equipment & Supplies
How to change the correction tape?
Changing the Correction Tape
1) Move the print carrier to the center of the platen using the SPACE or BS key.
2) To replace the correction tape, lift out the typing ribbon cassette (see Changing The Ribbon Cassette) and remove the two spools of the lift off tape by pulling them outwards.
3) Place the empty spool of new tape on the left pin so that the tape winds clockwise. Place the tape around the left guide. Pull the tape around the right
guide and place the loaded spool on the right pin so that the tape unwinds counter-clockwise.
Note: Make sure the sticky side of the tape is facing the platen.
4) Manually turn the left-hand spool in the clockwise direction, tightening the tape until resistance is felt.
5) Replace the typing ribbon cassette.
6) Press the CODE + = (SETTING) key.
Changing the Ribbon Cassette
2) Hold the ribbon cassette on both sides and lift up the front portion (where the ribbon is exposed) to remove the cassette.
3) To insert a new cassette, place the back end of the cassette on the cassette
holder on the carrier and gently press down on the front of the cassette unit it clicks into place.
4) Turn the ribbon feed knob counter-clockwise again to take up any slack in the ribbon.
5) Presss the CODE + = (SETTING) key.
Good Luck!
Oct 13, 2010 | Smith Corona Wordsmith 100 Typewriter
My heads on the xm1 seem to be dirty, ive used a sony cleaning tape, it only makes a difference for an hr or two taping, any sugestions
Firstly, I must explain how the MiniDV system works:
Although this may sound illogical, MiniDV camcorder heads do actually use a type of lubrication cassette system and there are 2 types:
- DRY lubrication (Canon, Panasonic, JVC etc)
- WET lubrication (Sony)
Now, if you haven't noticed already from the above 2 types, you are in fact using the WRONG type of cassette on your camcorder.
Although Sony cassettes are often readily available (and often perceived to be the best quality), by using Sony cassettes on a Canon camcorder (or Pana, JVC for that matter), you are in fact causing premature wear on the heads. So, the condition you are describing as 'dirty' heads, is in fact caused by the use of the wrong (wet type) cassettes on your DRY type camcorder.
Using "WET" type cassettes on a DRY system camcorder, can often leave residue on your heads, or worse....cause wear. The same principle applies to Sony camcorders - use only Sony 'WET' type cassettes, not Dry cassettes.
This also applies when using HEAD CLEANER cassettes - as indicated, you have used a Sony Head Cleaner cassette (this is a WET type cassette), when in fact, you should be using a DRY HEAD CLEANER cassette (Pana, Canon etc).
CAUTION: when using a head cleaner cassette, only playback the cassette for no more than 6 sec's at a time (anymore will damage the heads).
Summary:
For your Canon camcorder, use only DRY MiniDV cassettes (Pana offer cassettes from Studio, Professional to Master Quality), including DRY Head Cleaner cassette. This should improve the playback quality from your camcorder.
Mar 25, 2010 | Canon XM1 Mini DV Digital Camcorder
How to install daisy printwheel and cassette ribbon on Sears electric typewriter Model #161.53024650
Nobody wants to try so i'll give it a shot. All Sears typewriters are made by some one else. ROYAL, SCM, Olivetti ETC.) Most daisy wheels are released with a lever just l. or r. of the wheel pull it towards you and remove the wheel. There are 2 basic types of ribbon the ones that are released by a lever and those that just snap in.
Hope I was helpful
DickyO
Jan 25, 2010 | Office Equipment & Supplies
I have a Royal electric typewriter; TQ620 - Serial #4909759, I need to know the type of ribbon to use and general instructions.
Please contact anyone at www.inkribbonpaper.co.uk for the cassette ribbon for your TQ620. They sell it and will tell you how to use it
Dec 28, 2009 | Royal Office Equipment & Supplies
42 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Marvin
Marvin
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
