Question about iLO Televison & Video
Tv code for 2006 ilo tv model # lct27ha36.I have the remote that goes with it,but I don't have the tv code to program the remote control.
Posted by Linda Ingram on
5 Related Answers
Anonymous
SOURCE: Ilo remote control code
Yes the Emerson code 198 worked for my jumbo universal remote made my Innovage. I also have the ILO 32' TV and could not find the code but this one worked!!! Hope it helps
Posted on Dec 22, 2007
lefemmelinda
SOURCE: code numbers to set up iLo tv
Checked on line for any code there was that someone used for iLo t.v.'s, found two codes on your site that someone had used & used those & one of them worked. Thanks again!
Posted on Apr 02, 2008
Anonymous
  • 4 Answers
SOURCE: Remote control codes
for DirTV try 10463
for others try 0463
and for power and vol for some universal remotes try 720
Posted on May 29, 2008
Anonymous
  • 3 Answers
SOURCE: ilo tv/universal remote codes
Here are some to try, mine was 0189, but there are many to try. 0051 0189 0053 0198 1070 1024 1023. I think some listed codes for Emerson work as well.
Posted on Aug 06, 2008
Anonymous
SOURCE: ilo TV, universal remote
Ilo is made by Orion and/or Sansui.
My Ilo dtv2794B was programmed on Direct TV remote as follows:
In Direct TV mode press 'menu' .
Go to parental ,faves setup
Go to system set up
Go to remote
Go to TV
Select brand (Orion)
Follow directions from this point.
Good Luck>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
Posted on Jan 07, 2009
Model number LCT27HA36..will not turn on????
This TV is using a power supply MLT168A that has defective capacitors. Replacing the capacitors might fix it, but in some cases the failure is more then capacitors.
Write to [email protected] if you required further assistance.
Aug 17, 2009 | iLO Televison & Video
DishNetwork Remote won't program to control ilo EDTV
Hi, Hope this helps. I used code 720 for my dish remote to remote my ilo tv. It works great. Hope it works for you. Bob
Jan 11, 2009 | iLO 2600 Television
Can't get a single remote to work with Dish Network and ILO TV
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Mar 12, 2017 | Televison & Video
I need an ilo code for my charter remote so I can program my tv channels
Need to know the model of your charter remote. TV is ILO? OK, we are half way there..
Sep 09, 2008 | Televison & Video
Sony RMV210 Remote Codes for iLo LCT27HA36
Salutations Schaf1,
This happens with some manufactures. Thankfully some codes will work with other TV's. This is the "Code Search" starts. Your remote has a way to try other codes to see if they will work.
If all else fails it appears Sony has a support hot-line available at 1-800-822-2217 that maybe able to help you find the code. Just make sure you cover all the troubleshooting steps you've already done.
Hope you find that code.
Jon
Go Ahead. Use Us.
May 06, 2008 | iLO LCT32HA36 Television
ILO TV remote
order the factory remote.800-216-5156
Mar 20, 2008 | Televison & Video
Ilo LCT27HA36
Contact the manufacturer or go to their web site for manuals etc.
Feb 02, 2008 | iLO LCT32HA36 Television
Ilo lcd tv lct27ha36
I having the same problem. Called the company $80 for a new remote. I only paid $300 for the TV. The company said they have not given out the code for the television. What a CROC! Like the TV, but probably won't buy another.
Sep 23, 2007 | iLO V27DMBX Television
Televison & Video Logo
43 people viewed this question
Top iLO Televison & Video Experts
Lee Hodgson
Lee Hodgson
CoppellTVRepair.com
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
