Question about Whirlpool Dishwashers
Have a whirlpool wdt750sahz dishwasher. It will fill with water then nothing. Can drain water out. How to put in diag mode? Unit does not have digital display
5 Related Answers
Anonymous
SOURCE: Whirlpool dishwasher will not start
There is a small replacable part on the control panel circuit board which is like a fuse. It actually is a temperature fuse and it blows when the environment gets too hot for the circuit board. Unplug the dishwasher and take the door apart so you can see the circuit board. If you trace the power wires one of them leads to a little white module with 2 electrical tabs. Unplug the 2 wires and unsnap the module. You can check it with an ohm meter. IF its good the meter will register almost a short. f it's bad it will be open. The parts place I went to didn't even need a model number and he says he goes through a lot of them.
Posted on Nov 09, 2008
douglas smith
  • 1462 Answers
SOURCE: My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Posted on Nov 26, 2008
Cleverer2
  • 298 Answers
SOURCE: Dishwasher will not drain (water just trickes out) fill is good
Drain valve not opening or pump impeller loose on shaft - is it washing ok?
My guess would be drain valve not opening. It is a 110v solenoid and they get stuck or burn up. New solenoid costs ~$20.00
Posted on Mar 26, 2009
Joe Povoas
  • 111 Answers
SOURCE: GE 530 built in dishwasher does not fill with water
water valve and level switch
Posted on Jun 17, 2009
localwonder
Michael Masters
  • 6784 Answers
SOURCE: Motor just hums during the wash cycle. Put it in
OK, that piece of glass may have jammed the wash impeller. this will destroy the motor windings. you will need to gain access to the circulation motor asap.the impeller is attached to the motor that is housed within the pump casing(upper). try to manually move the impeller. if its stuck, try ot remove the obstruction.
It is possible that, the motor is already damaged to the point of no return. in this case, replace the circulation motor. your drain pump should be ran by a totally separate motor(wax).
**NOTE
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
Posted on Jun 21, 2009
My whirlpool dishwasher is filling up with water when not in use
replace the water control diaphragm or unit
it is leaking and not shutting of the water supply
Apr 28, 2018 | Whirlpool Dishwashers
Does not Wash
first check if there was an object that obstruct the motor, try to clean that area, and run again the unit, if the problem was still there, then could be the washer motor was broke.
Aug 07, 2008 | Whirlpool 24 in. GU1500XT - Multiple Color...
Dishwasher slowly fills after cycle
If water slowly fills in the tub when not in use.
a) Most likely your machine inlet water valve not seating properly and closing. Change the machine water valve.
b) May be sink drain water back flowing to the tub. But you have checked that.
So it has to be the machine inlet water valve.
Apr 11, 2015 | Whirlpool Dishwashers
Maytag jetclean quiet plus fills but wont wash or drain.
The mother board is going out, or the drain pump is failing. Try un plugging it...... by which i mean turning the power off to the unit and doing a soft reset. See if it recycles into the normal mode and works.
Mar 06, 2015 | Maytag Dishwashers
Kitchenaid DW KUDS30FXSS Cycle starts then I hear a solenoid actuate 4 times then unit goes into cancel drain cycle
Here's a link for the repair manual for your dishwasher:
http://www.appliancerepair.net/kitchenaid-dishwasher-repair.html
Concentration should be on Chapter 2 subsection 2-3 "No Fill"
Then go to Chapter 6; subsections 6-2, 6-3, 6-3a, 6-3b, 6-3c, and 6-3h for testing procedures on relays, actuator valves, etc.
Nov 30, 2013 | KitchenAid KUDS30FXSS Builtin Dishwasher
My bosch dishwasher will not fill with water. I have manually filled it but it just pumps it out when I switch it on.
the unit is going into drain mode. check your hose for leaks. when water leks in the base of the unit the float switch is activated and the unit will stay in drain mode until the water is removed. check float by removing side panel and look into bottom base for water.
Feb 25, 2010 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Unit will not drain. It will fill with water in normal manner. Circulating pump also works normally. Float switch seems to be sound. But the wash water is not expelled as it ought to be.
Something simple to check is the drain hose. I am an installer and have seen this many times and people will buy a new dishwasher after putting in a new garbage disposal. If you did, did you remove the knock out plug from the disposal? Next, remove the drain hose end from under the sink and try sucking the water out with a wet/dry vac. All the water from the dishwasher should easily be sucked out from any dishwasher except a GE brand. If not, your drain hose is clogged.
Sep 25, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
My whirlpool dishwasher cleans well but once the rinse cycle is completed and drained the next day the washer has water in it. HELP!
it could be a bad fill valve.to chk this ,open the door and look for the inlet hole from where water comes in.if u see and droplets of water coming down the hole then it is the fill valve.when machine is off the fill should be closed and no water should come in.
other thing could be ,if u have hooked up the drain pipe of the unit directly to the food disposar instead of going through air gap mounted at the sink then some water from the disposar could flow back into the unit.units have chk valve valve built in drain pipe but some times they work 100%.also chk 2 c if water insinde unit is dirty or fresh to confirm above things.
Aug 22, 2009 | Whirlpool DU1055XTS Built-in Dishwasher
Whirlpool dishwasher adg7540
where do you live that model doesnt come up in my data base the first thing your washer should do when you turn it on is drain then fill then go to wash try this it should put it in self diag if this dont work reply we will try another HIGH TEMP SCRUB, AIR DRY, HIGH TEMP SCRUB, AIR DRY push thoose see if it goes into self diag
Jan 24, 2008 | Whirlpool 24 in. ADG7540 Built-in...
Whirlpool built in dishwasher. not aware of model number
Putting vinegar in the bottom of the dishwasher is not going to help because it has nothing to do with the FILL cycle. The bottom (or sump) actually is used during the WASH and DRAIN cycles. I would check the fill port where the water inlet hose goes into the side of the wash tub. You will need to pull the unit out and locate the inlet hose on the SIDE of the dishwasher. The hose should be a black rubber hose located on the left-hand side of the machine. I had a very similar problem that turned out to be calcium deposits clogging the fill port BEFORE it got to the fill valve. With the unit turned off, I removed the rubber hose and used a small screwdriver to poke straight down into the fill port and break up a bunch of calcium. The unit worked fine after that. It is normal for some dishwasher models to drain if they do not detect enough fill water, or if they detect a leak. Usually when the fill port becomes restricted or clogged you will find puddles of water forming under the dishwasher. You might want to remove the bottom panel and check for leaks as well (if you haven't done so already). If you check the fill port and it is clear, the fill valve could be a possibility as well. However, you mentioned you could hear water running which leads me to believe that you have a simple clog somewhere...but, the valve could have accumulated some deposits as well. Check the fill hose and let me know. Good luck and I hope this helps you. PS Another common mistake people make is to put drain cleaner in their dishwashers. This can damage the pump and chopper assembly. Not to mention, it could be harsh on the some of the rubber seals. Not a good idea.
Jul 30, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
Dishwashers Logo
120 people viewed this question
Top Whirlpool Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Marvin
Marvin
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
