Question about Yamaha Audio Players & Recorders
Yamaha RX V457 sound cutting out when using Netflix, Prime, etc
    Top Expert:
  • Yamaha Master
  • 30,785 Answers
Check the audio cables.
Posted on Dec 08, 2019
6ya staff
SOURCE:
goofduck
Jeff Adkisson
  • 490 Answers
SOURCE: on my radio the rx keeps coming on and cutting off the radio
sounds like you have the cb radio on and it overrides the radio when it picks up someone talking
Posted on Apr 13, 2009
mlapres
Mike LaPres
  • 757 Answers
SOURCE: no picture on my yamaha rx-v661 receiver
Connect to your HDMI out from the receiver to your television.
Posted on Jun 18, 2009
perpetually
perpetually
  • 360 Answers
SOURCE: I want my Comcast remote & Yamaha RX-661 to communicate??
30176 or 31176
I am guessing at what remote you are using, so the code may not work. If that is the case, go to the following link and pick your remote from the picture list.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Posted on Jul 13, 2010
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: I have a RAV254 remote
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remotes", check the 'include description' box. Usually cheaper than the vendors.
Posted on Jul 11, 2011
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: My Yamaha RX-V457 has stopped
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on; or it may turn on but produce no audio to the speakers.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Sep 20, 2011
My yamaha_rx-v457 is automatically switching off when i turn on
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .
if it stays on whit no wires attached than u have short connection at speaker wires .
if doesn`t come on then try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode happened to me on RX-V592
Dec 21, 2012 | Yamaha RX-V457 Receiver
The power do not come on
download the service manual from http://elektrotanya.com/yamaha_rx-v457_v557_sm.pdf/download.html its a free download ,in another forum there is a fet transistor 2sk3850 on the sub trans power board replace it and also suggest cleaning the relay contacts on the same board .. hope that helps
Feb 25, 2011 | Yamaha RX-V457 Receiver
My surround sound speakers don't work. No power
LCD will display which speakers are active. And this depends on 2 things: the source signal and decoder mode.
If source signal is stereo, only front L+R speakers are used. For 5.1 signal (for example DVD over HDMI / optical/coax spdif) all speakers installed (which are not set to None) are used.
To listen to stereo input signal using all speakers, switch decoder to enhancer mode.
Feb 24, 2010 | Yamaha RX-V457 Receiver
No picture on my yamaha rx-v661 receiver
Jun 04, 2009 | Yamaha RX-V661 Receiver
On my radio the rx keeps coming on and cutting off the radio
Feb 20, 2009 | 2007 Yamaha Royal Star Venture
Hdtv set up with receiver and comcast hdtuner
Are you using a comcast box or trying to hook up directly with cable?
Dec 30, 2008 | Yamaha RX-V457 Receiver
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
