Question about Home
I received this Melodies in Motion model # QXM377BR last Christmas 2018 as a gift, In the middle of the hourly clock cycle it just stops. Batteries have been changed and the compartment cleaned. What do I need to do? Please help!
SOURCE: Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Posted on Nov 12, 2008
SOURCE: Canon PowerShot A510 "change the batteries"
This may be a bit late, but I may have found a solution for this problem.
I haven't tested it thoroughly yet so it might me a coincidence.
What I did:
BE CAUTIOUS WITH THE SMALL METAL PARTS!
Screw off the small metal plate that connects to the batteries.
Put some tape on the metal parts that are underneath it (watch out there's a spring in there and it can 'jump' away rather easily).
Screw the plate back on.
I put in the same batteries in the camera as when it said "Change the batteries" but now they work (for quite a while and not empty).
I hope it works for you too. :)
Posted on Feb 11, 2009
SOURCE: skyscan atomic clock model no 88902
Instructions for setting the clock can be found at:
http://skyscan.info/content/index.php?option=com_content&task=view&id=57&Itemid=40.
Posted on Apr 12, 2009
SOURCE: Lava Lamp is new, not working, spring loose on bottom, no blobs
The lamp is made of wax and alcohol. Try inverting the bottle several times. The aim is to get the wax to fall to the bottom. Try shaking it, especially when the fluid is warm. This may help break the wax up to where it can begin cycling on its own.....careful, though, you don't want to burn your hand. I have done this several times, and it works!
Best regards, --W/D--
Posted on Jul 31, 2009
SOURCE: Outside temperature not working on
hello lucy... you most likely have some corrosion in the outdoor component. Remove the batteries from the outdoor component and clean the battery contacts with the eraser end of a common pencil. Reinstall the batteries and then give it up to 8 hours to start reporting accurately again. Joe
Thanks for choosing Fixya!
Posted on Feb 18, 2011
Nov 13, 2017 | Home
Dec 08, 2015 | Seiko Melodies in Motion Clock
Mar 01, 2015 | Seiko Melodies in Motion Clock
May 04, 2014 | Seiko Melodies in Motion Clock
Feb 18, 2014 | Seiko QXM265BRH Melodies in Motion...
Dec 06, 2013 | Seiko Melodies in Motion Clock
Feb 23, 2011 | Seiko Melodies in Motion Clock
Jun 26, 2010 | Seiko Melodies in Motion Clock
104 people viewed this question
