Question about Fisher Dishwashers
Hi Dan-
I found this link.
https://www.fisherpaykel.com/vault/pdfs/pdf_usecares/599864A_DD60_userguide_CN(EN).pdf
If you are looking to reset the error code. On page 28 "Fault Codes", it talks about "How to attend to a fault code".
Hope this helps.
I also found this youtube video on Fisher & Paykel dishwasher repairs.
https://www.youtube.com/playlist?list=PLLkJYbdOr3lovxlEUZUJRSzBKsA2-6giD
Hope this helps.
Posted on Nov 29, 2019
SOURCE: Fisher & Paykel DD603 Disher Drawer Service Manual
You can get fisher paykel service manuals here:
http://fisherpaykelparts.net/index.php
Posted on Dec 11, 2008
SOURCE: How do i fix an F5 error code on a Fisher &
I am assuming you have the DD605 double drawer dishwasher. Is the problem F5 on both drawers or just one?
F5 code involves the drawer lid seal and will need a bit of effort to check and fix.
Take the drawer out and inspect the inside of the top panel for a black rubber strip. If it is broken or not responding to up down movement then it needs to be replaced. In addition the actuator motors on each side that drive the seal could be faulty.
If you are not comfortable with repairing slightly complex apliances then you may have to call the technician.
Posted on Aug 19, 2010
SOURCE: Fisher & Paykel Dishdrawer DD603H.
Hi F2 error is displayed when control won't sense motor to be
rotating, usually occurs due to frozen/bad motor or stuck motor rotor or the
RPS sensor or a bad stator assembly. If the motor rotor spins freely and both
impellers are securely attached then the issue is with the RPS sensor. If the
motor won't rotate then it is the motor rotor that has to be replaced. Hope
this helps...please post back for further assistance. Daniel
Posted on Jun 20, 2011
Error Code - F2
Which LED - Delicate LED
Reasons - The motor has not been sensed rotating
Likely Causes
_ Foreign object has jammed the rotor
_ The rotor has failed
_ The hall sensor has failed
_ The electronic controller has failed
