Question about Military Time Watches
What time is it military time 22:30? - Military Time Watches
Posted by Jesse Nelson on
Amelia Rossi
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 7 Answers
Military Time 2230 is: 10:30 PM using 12-hour clock notation, 22:30 using 24-hour clock notation.
https://speedtest.vet/ https://vidmate.bid/ https://123-movies.red/
Posted on Jan 10, 2020
EmBalmU
    Welcome Back:
    Problem Solver:
  • 13 Answers
10:30 pm
Posted on Nov 28, 2019
Can Fitbit Charge 2 time be changed to 24hour?
You can change to military / 24 hour clock in your profile settings at: https://www.fitbit.com/user/profile/edit
Dec 28, 2017 | Military Time Watches
How to Quit military time on Armitron IW-YP 12585A
Hi Bill.
Please allow me to try to help you.
Here is where you could find the answers to how to quit military time on Armitron IW-YP 12585A...
https://oureverydaylife.com/how-do-i-change-from-military-time-on-my-armitron-watch-12277699.html
http://office.manualsonline.com/support/armitron/clock/how-do-i-switch-from-military-time-to-normal-time--5401972
You could also find help in the form of the video that I have added here.
Hope that helps.
Best wishes. Regards.
Nov 06, 2017 | Armitron Watches
To be able to change to analog time from military time
Go to your events/calendar. Click the little settings symbol there. Then uncheck 24-hour time and save. How do I change my clock settings from military time to regular time.
just found this on the internet dont no if this will help you out if not let me no.
Nov 19, 2016 | Able Watches
What time is 13:09 in military time compared to regular time?
1pm plus 9 minutes. Military time uses 24 hour clock
Feb 23, 2015 | Military Time Watches
Turn off military time
This baffled me for a bit...Finally I just took the batteries out, then put them right back in and it was no longer on military time.
Apr 06, 2013 | Brookstone LEGO Ninjago Kai Mini-figure...
My timex indiglo Ironman triathlon watchhas twelve hours of military time and then twelve hours of regullar time. HOW CAN I GET RID OF THE MILITARY TIME AND GET ALL TWENTY FOUR HOURS OF REGULAR TIME???...
Actually all the hours are military time. They are the same for the first twelve hours of the day. If you go through the setting procedure it will ask you if you want "12" or "24" hour time. Select 12. "24" is military
May 23, 2011 | Timex 27191 Wristwatch
My TGHK watch is stuck in ''military time'' and I've lost the instruction manual. Any ideas how to get it to am/pm mode?
advance the hours. The first time you go through the 24 hour cycle, it will be in am pm mode, the second time in 24 hour mode, the next time in am pm. Just keep advancing the hours until it comes up the correct time
Nov 03, 2009 | Watches
How do i get my athletic watch off of military time? It's a water resistant watch up to 165 ft. model # aw60447w
military time:
1. When setting the time on your watch, IF you watch can change to Military time(and most can)
2. when you are adjusting the hours go through a full 24 hour cycle. You'll notice that the 2nd time through it is on military time.. 3rd time through back to 12 hour day AM/PM cycle .. 4th time back to Military.
So you can do this as many times as it takes to get to the right time ..
In 24 hour time you will see an "H" displayed where you normally see and "A" for AM and "P" for pm.
Sep 23, 2009 | Watches
Set watch
I have a G Shock DW-004 made in 1997. I had this same problem, and I tried everything to change TO military time and back to standard time. I just read the bit to try and was about to do it. I pressed the top left button to get the time to flash, and hit the light button by accident (the one with the big G on it) and VIOLA! It changed to military time. So in my model, anyway, the G light button (under the display on the edge of the watch body) changed the time to military from standard and back again, when the time is flashing.
Feb 21, 2008 | Watches
Watches Logo
61 people viewed this question
Top Military Time Watches Experts
Kardoc
Tom Chichester
Bill Boyd
Are you a Military Time Watch Expert? Answer questions, earn points and help others
