Question about Ovens
Model Sf367peyn4. How can I light the pilot? - Ovens
Posted by Patty Atkisson on
Charcoal grill model no BG7-05
turn gas off and clean out all lines going from gas valve to pilot with compressed air. put the lines back together (be sure they seal)
try the pilot again
Nov 15, 2013 • Fagor Ovens
Our 17year old GE gas oven/broiler stopped lighting today. What might be the problem? Stove burners work.
Most likely culprit is the igniter.
When you turn the oven on it opens a gas valve allowing a small amount of gas to flow thru the pilot light. The igniter then lights the pilot and when the sensor determines the pilot is lit it opens th emain gas valve and the oven lights. If the igniter fails and doesn't light the pilot the sensor doesn't heat up and it shuts down the pilot and nothing works.
The igniter is usually accessable under the oven by removing the drawer. It has a single wire attached and looks like a short cigarette made of ceramic witha metal tip.
You didn't provide model number so I can't give you part number but if you look it up here you may be able to get one from Sears
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
May 18, 2011 • Ovens
2answers
Pilot light not workimg
. You light the gas escaping from the tube, and it burns all the time.
Mar 11, 2011 • Ovens
How do I light pilot light, the top burners will light,but the oven won't come on please respond asap
the pilot assembly should be located behind the drawer ..pull door open at the bottom of range pilot assembly should be located way in the back ..look with flash light its their..let me know if it works ..good luck ..a model would help me more and how old is it
Aug 25, 2010 • Ovens
Pilot light keeps going out when turning on oven
Sounds like the GSD. The Gas Safety Device valve needs replacing
Oct 17, 2017 • Ovens
Maytag gas oven doesn't heat, but oven's pilot light is on.
Get the oven checked out by a professional, if you have a gas leak you can easily blow up the entire house and you with it. I think you have a faulty gas valve based on what you wrote
Mar 03, 2017 • Ovens
Pilot light
It was an electric ignition
Thank you
Pilot Light - Frigidaire Model FGF326ASF
Hello jaronwayne
Welcome,
That range does have sealed burners.
Are you sure it has a pilot light and not Electronic ignition?
Where I live , if we call public service they will come out for free and light it for you!
I'm checking that model and I'll get back to you!
Huuum
2answers
The pilot light for the oven went out.
Relighting Your Furnace's Pilot Light
furnace1.jpg - Turn off the gas at the main valve at your utility box - Wait five to ten minutes for gas fumes to waft away - Get a long match—yes, a fireplace match, not a standard match - Set the gas valve on your furnace to "pilot" - Press the red button as you hold the match to the pilot valve - Keep pressing the red button for 30-60 seconds so the pilot can heat the thermocouple. Release the button and see if the pilot remains lit - If pilot goes out, wait five to ten minutes and repeat the process - Once the pilot stays lit, turn the main gas valve back on - If the pilot light continues to go out, call a technician, who may need to adjust or replace your thermocouple or adjust your pilot
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Are you an Oven Expert? Answer questions, earn points and help others
