Question about Aiwa Audio Players & Recorders
Cassette door will not open on my aiwa XH-A1000 how can i fix this
Posted by Harry Redcliffe on
5 Related Answers
ABRsvcs
  • 4234 Answers
SOURCE: aiwa z-1800, cassette deck problems,
The auto reverse is a two part system, the heads are moved and the motors change direction. Slipping belts, broken gears, dirt in the gears can all cause this type of symptom. These are decent units and I would invest in a general overhaul to bring it back to factory spec. I have done a number of these in the past and would recommend the overhaul. Expect $10-$20 in rubber parts plus the local labor rate.
Dan
Posted on Apr 03, 2008
Anonymous
  • 319 Answers
SOURCE: cassette doors
Bent or broken door latching part. Take in for service
Posted on May 07, 2008
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: problem with AIWA TP-M130 micro cassette recorder can't get tape out
Following 2 pics of exploded view will help you to solve problem with Aiwa tape.
Need further help. let me know.
Posted on Oct 22, 2008
Anonymous
SOURCE: aiwa cassette deck won't eject
I had this problem on an AD-S40. Turned out to be the drive belts, which had stretched, resulting in the fact that the motors couldn't drive the mechanism through it's various load cycles of opening/closing the captain roller, etc. as required to operate the mechanism. Stuck in mid-cycle, the doors would not open.
After removing the case cover, you can turn the belt driven wheels by hand to complete the cycle, so that you can eject. Then get new belts (several outfits sell belts based on length, on line). You don't need to do much to replace the belts -- after unlocking and getting the tape out, it was only a couple of screws to remove the mechanism, as a unit, and there is no need to fuse with the circuit boards and such. Easier than I expected.
Posted on Apr 20, 2009
Anonymous
SOURCE: I have an AIWA CD3
where can i buy an aiwa cd 3 deck?
Posted on Jan 06, 2011
Aiwa AD F660 cassette deck. Having changed the drive belts, the eject button does not now work. Hook holding the cassette door shut does not drop enough to release. How can I fix this? Thanks, Brian
Have you trapped wire or something near the hook mechanism stopping it from getting full travel when the button's pressed?
The nice people at HiFiengine have a service manual for the deck, free you just need to join.
HTH
Aiwa AD F660 Manual 3 Head Stereo Cassette Deck HiFi Engine
Jan 19, 2018 | Aiwa Audio Players & Recorders
I have 2 AIWA CX-NA303 volume can only be controlled from remote. Cassettes no longer play and doors won't open to remove them. Where are repairs available?
Search Results
    images for aiwa audio shelf systems service manual
    Free Aiwa Stereo System User Manuals ' ManualsOnline.com
    audio.manualsonline.com > ... > Aiwa > Home Audio Aiwa
    Products 1 - 50 of 107 - Aiwa STEREO RECEIVER User's Manual AV-S17. Pages: 0 Saves: .... Aiwa Compact Disc Stereo System Operating Instructions CX-NA22
Oct 21, 2015 | Aiwa Audio Players & Recorders
I got a cassette tape stuck in my Aiwa compact disc stereo system and broke the door on one side getting the cassette out. There seems to be a piece broken on one side. Door will not stay closed. I
Google AIWA service centers or go to the AIWA website for help through Customer Service. Good luck!
PS Best Buy Geek Squad may offer repair options.
Jan 14, 2018 | Audio Players & Recorders
AIWA XH-a1000. Won't turn on. Any time I try to turn it on I hear a click in the back and that is it. Any solution to my problem ?
This is the unit going into Protect mode. This is usually common when the audio chip goes bad or a power transistor. Need a schmatic to check voltages and pcb lines.
May 23, 2014 | Audio Players & Recorders
I want to buy aiwa XH-A1000 but dont know from where i can buy this system and how much i have to pay for that please tell me thanks
me gustaria comprar partes del cerebro del aiwa xh a1000 para cualquiera que tenga inventario de partes me puede avisar necesito lector de discos o si se puede la targeta completa por que el audio tambien no funciona.
espero me puedan ayudar saludos...
May 26, 2010 | Aiwa XH-A1000 Shelf System
Good day,i have an aiwa HX-A1000 stereo system with a 3 cd changer,casette player/recorder,and 5.1 surround sound.After having it in storage for several years,i have lost the owner's manual and cannot seem...
there is a problem with the stereo firmware. It is not anything you are doing wrong. It is a common problem with all Aiwa's. If you are handy with electronical repair, you can test and replace the bad resistors. Otherwise, it will have to be taken in for diagnostic testing.
May 11, 2009 | Aiwa Audio Players & Recorders
Problem with AIWA TP-M130 micro cassette recorder can't get tape out
Oct 22, 2008 | Audio Players & Recorders
76 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
