Question about Tablets & eReaders
Have an Alcatel, model 8080 pixi 3 tablet. I put in a 32gb sd card and am unable to tranfer videos, pics or files to it. Need help, thank you.
  • 646 Answers
Does the tablet recognize the SD card?
Posted on Nov 28, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: SD card capacity
Yes, the hardware is SDHC-compatible. You just need to apply Microsoft hotfix KB934428 for Windows XP (http://www.microsoft.com/downloads/details.aspx?displaylang=de&FamilyID=6edfb30f-b1ab-42a8-a330-acd6762961bc) and you are set. 16GB SDHC working like a charm.
Stefan
Posted on May 14, 2008
Jaysan Lunt
  • 16 Answers
SOURCE: how do i upload home videos and pics from my tablet to my home computer
1) Connect your Pandigital Planet to your PC via USB Cable
2) Wait until it shows up as a new drive
3) Look for your video files in either the INTERNAL or SD storage
Should be in a director like \DCIM\Camera Folder
4) Drag the CONTENTS or the FOLDER to your DESKTOP or other selected area on your PC
5) Disconnect the Pandigital Planet and your all done
6) Smile
Hope that Helps
Jaysan
Posted on Jun 16, 2012
Joshua Falls
  • 22 Answers
SOURCE: have an android tablet but have lost an inside SD
Well their is plently of websites out their that you can download "flashes" like the software, http://www.redmondpie.com/download-and-install-android-2.3.6-gingerbread-grk39f-on-nexus-one-how-to-tutorial/ this is a good website for getting the software depending on what version of android you have and then tells you how to do it incase you dont know.
Thanks
Posted on Aug 06, 2013
sschoemann
Scott Schoemann
  • 150 Answers
SOURCE: yarvik manuals
how are you using the card? you need to move the software that you can to the card and set it to be run from there. you also need to clean your tablet regularly, just like a laptop. not shutting apps down properly will leave your system full of garbage and no room for anything. this is true for ALL tablets
Posted on Sep 05, 2014
shadowchb
  • 268 Answers
SOURCE: i have an irulu tablet. I inserted a 32gb sd
Most apps do not natively install to an SD card when downloaded from the play store. You have to have an app like AppManager, that has a function to 'move' apps from internal storage to an SD card, or use a manual option in the Android Settings section to move each app individually.. If you are that tight on space that you cannot load any new app, you may have to delete or move something from your internal storage so you can download AppManager or some similar app, and then move as many apps as you can to your SD card. If you have a lot of photos and music you can try moving that to the SD card if your player/viewer software will allow you to find it there. Best way to move bulk items (music/photos, not apps) is to connect to a PC through USB, which brings up your internal storage and the SD card as external USB storage items. Then copy from internal storage to SD card through your PC. Best to establish folders on the SD card to hold these items and then tell your app where they are.
Posted on Dec 04, 2014
How do I transfer pitchers and video from my next book 8 coudcor tablet to my pixplus micro SD 32gb card l am new to all of this?
You need to download a file manager on the tablet insert the sd card in the tablet and use file manager to copy files from tablet to sd card hope this helps
Jan 17, 2018 | Tablets & eReaders
Moving pics to sd card that has available space but tablet says sd memory full.
available space does not mean that there will be much space. when putting sd card in any tablet, tablet reserve some memory to process. please explain how much memory left. also check any hidden files and icons from sd card.
Oct 23, 2017 | Samsung Tablets & eReaders
My tablet keeps giving me error message. Insuficcant space on tablet to download apps
This means the internal memory is full and the only way to add apps is to uninstall other apps that you have installed. Check to see if you have apps you no longer use and uninstall them.
Jan 02, 2017 | Tablets & eReaders
Can I put a200gb SD card in a RCA tablet
It depends on the model of your tablet. If it works with SDXC cards then yes it will. If not, no.
Nov 03, 2016 | Tablets & eReaders
How to down load films to a 32 GB card Hudle2.Thanks
OK, to accomplish this you need 2 hings:
1. A micro sd card. (Which I gather you already have one)
2. File manager installed in your tablet.
Now, if the tablet support micro sd card, you are all set. Download the file manager, it could be Astro, ES File Explorer, etc...
Once installed, open the file manager. The tablet storage, which is known as internal storage, it is display as sdcard/storage (or sometimes as internal storage). Once you tap the internal storage, everything that is installed in your tablet will be display; (Android, DCIM, etc...) Now you need to look where are the pictures or films saved at. It is usually DCIM/Camera. Once you have found the pictures that you want to move or copy, long tap the films, depending on the file manager app, you must tap copy or move (NOTE: Since every file manager is different, some takes a little bit of extra steps, others requires for you to open a menu). Once you had chose to copy or to move it, look for the external sd card location, which will also be located at sd card/storage/ (32gb external storage) and choose this location to paste your films or pictures.
Another way is by using a computer. Make sure that you have all the drivers needed for the computer to recognize your tablet, you also need the usb charge cable. Once the computer recognize it when the tablet is plug in to the computer, open it by double clicking, there should be 2 storage display under the tablet folder: Internal storage and 32gb. external storage. Open the internal storage, look for where the films are saved (just like I explained with the file manager), choose the films that are to be move or copy, and jus drag and drop or press ctrl and C to copy, go to the external storage, open it and press ctrl and V to paste.
Jul 10, 2016 | Tablets & eReaders
HELLO MY NAME IS ANDREA TILLMAN AND I WANTED TO KNOW HOW TO MOVE MY MUSIC AND VIDEOS TO MY SD CARD FROM MY TABLET PLEASE AND THANK YOU SO MUCH
Andrea, Check the attached links,instruction and guides on how to move vids. to SD card, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Galaxy Tab How do move photos videos and other files on my Samsung Galaxy...
Transfer pics to sd card from Samsung tablet
Moving files from the tablet main HD to the microSD card
Jul 08, 2016 | Samsung Tablets & eReaders
My pad says the internal storage is almost used up...I inserted an sd card, but not sure how to get the tablet to read it so that I'm able to install more apps and games.
Good afternoon Linda!
You can view your manual here
RCA RCT6077W2 Manuals . If you go to page 10
RCA RCT6077W2 User Manual Micro usb Headphone Micro Sd it notes a couple of important caveats on the card:
  1. You can use MicroSD or MicroSDHC type cards
  2. Size limit of 32GB
  3. You are warned never to insert or remove the MicroSD card in 'On' mode (i.e. only insert/remove the card when the tablet is off)
Aside from that, it looks like things should work. To be sure on what is the root of the issue, you can:
  1. Insert your card into another device to verify that it works
  2. Format or Re-Format the card - the SD Card association has a formatting app here:
https://www.sdcard.org/downloads/formatter_4
  • Make sure the card is legit. If it was purchased, for instance, off of Ebay, or other not-so-top-tier online store, as likely as not it's a fake made in China, likely with guts from manufacturing rejects. You might, for instance, get a card marked 32Gb that actually has a 2Gb chip in it with a hacked controller that says it's 32Gb. It'll seem to work OK for a few files, and at some point will just write your files into no-where. SD Insight, a free checker app for Android phones can be picked up here
SD Insight Confirm your micro SD card authenticity instantly amongst many options.
Hoping this helps!
D
Dec 18, 2015 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
How do I set my tablet to put everything on my mico card?
Not all applications can be transferred to micro card. To know and transfer a particular application
1) go to settings then to application manager then
2) select the application you wish to transfer. If that can be transfer it will show in application info to tranfer to sd card.
3) click transfer to sd card.
May 26, 2015 | Nextbook Premium 8 Se Android
Can,t play files from external sd
Some devices do not like certain brands of SD cards. I once had a tablet that would not read my 32GB card, but my phone would. Try a different brand of SD card and see if the issue is resolved.
Jul 19, 2014 | Proscan 7-Inch Capacitive Touch Android...
Sd card
The SD card is not counted as RAM Memory.
RAM memory is included inside the tablet and is not upgradable.
The ram in your tablet is RAM DDR3 512MB.
Tablet PC Android 4 2 Tablet PC 9 M9100
Apr 16, 2014 | Kocaso NEW MID M9000 9.0 " Android 4.0...
Tablets & eReaders Logo
70 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
