Question about Panasonic Cameras
Panasonic Lumix DMC-FH27 = Insert SD card again = appears on the screen
ChinthakaJ
  • 943 Answers
Have you tries a different SD card? SD card could be faulty.
Posted on Nov 28, 2019
5 Related Answers
Dennis Maeder
  • 257 Answers
SOURCE: None of my SD cards (I have 4) will work with my panasonic lumix
This camera uses the SD standard - not SD HC.
Be sure you are using a compatible card!
The highest capacity mentioned in the manual is 1GB althought the SD stanard supports up to 4GB.
Posted on Dec 14, 2009
drifterK
Catalin Turcu
  • 4924 Answers
SOURCE: HOW DO I FORMAT AN SD CARD FOR MY PANASONIC LUMIX
be sure it is not blocked. (it has a locking button on the side) and after that into the menu of the camera look for format reset card ...this is the best way to do it cause it will format it on the way camera will support it ...Beware cause this will delete all your pictures..
usually the format feature will be on the view picture mode...around the option for delete single or multiple picks..
but if this is too hard ..just nsert the card into a card reader in a laptop or computer ...go to my computer folder...it will be seen as a removable storage device ..click right on it ..and than format ...choose to format in fat 32 not in ntfs cause the camera may not read it after that ..
so ...fat or fat 32 will be the mode...and if you have patience do not do it in the quick mode..cause it may cause damages in the long term ..(after a few times)
Posted on Apr 17, 2010
Anonymous
SOURCE: I have a : panasonic Lumix DMC-LZ3 Digital Camera
Page 92 of owner's manual for DMC-LZ3 states "Do not use memory card larger than 2GB".
Posted on Sep 24, 2010
  • 102366 Answers
SOURCE: I have a Panasonic Lumix
There are no SD memory cards 4GB or larger because the Secure Digital standard limits card capacities to 2GB. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in the DMC-FZ30. You will need to stay with SD cards 2GB and smaller.
Posted on Feb 25, 2011
Ty Price
  • 11967 Answers
SOURCE: How can I transfer internal memory pictures to an
In the menu system of the camera, scroll until you find "copy" where you are given the option of copying the internal memory to a card in the camera.
Posted on Jul 18, 2011
Insert sd card again
At this time we recommend you use a different SD card and format it. SD cards can become corrupted and the camera may not recognize your card any longer.
Apr 13, 2014 | Panasonic Sale Lumix Dmc-ts20 Waterproof...
Self timer on lumix dmc-fh27 Cannot find the
Attached is an image of the Self timer function from the operating manual.
Oct 01, 2013 | Panasonic Lumix DMC-FH27 / DMC-FS37...
I want to clear the "internal memory" for future use. Cannot find the icon/command to do that.
First, you need to remove the SD Card from the camera if it is inserted. Then go into the "Setup" menu and scroll to "Format" and follow the prompts. Hope this helps.
Aug 29, 2012 | Panasonic Lumix DMC-FH27 / DMC-FS37...
Panasonic FH27 MANUAL
All currently available downloads, including the user manual, can be downloaded from the Panasonic web site here: (click here)
Jan 09, 2012 | Panasonic Lumix DMC-FH27 / DMC-FS37...
Where does Lumix® digital camera store the pictures I take?
Unlike 35mm cameras that store images on film, Lumix® Digital Cameras store images on SD Memory Cards, which make sharing and storing your pictures easy and convenient. You simply insert an SD Memory Card into the camera, take pictures until the card is full, and then you can transfer the pictures onto a compatible PC. Once you saved all your pictures, you can erase the card and start all over again.
Aug 30, 2005 | Panasonic Lumix DMC-F1S / DMC-F1K Digital...
Cameras Logo
Top Panasonic Cameras Experts
ENFORCER
deton8 von Splosion
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
