Question about Home
I am trying to get my shower handle off the wall. I took the side screw out and I still can't get it off. Help!
Posted by Kirk Esterby on
5 Related Answers
dragonsthatk
Albert Getty
  • 547 Answers
SOURCE: single lever moen shower valve -can't remove handle
if you have taken out screw then pull off if you have a handle puller use it
Posted on Feb 23, 2009
Donni Steen
  • 687 Answers
SOURCE: how do I remove the single faucet handle to replace it.
There is a set screw in the handle, it can either be a hex screw or it can be a philips head screw depending on which faucet you have. If you have a clear decrative handle then there is a cap that you remove and the screw is behind it. Once you remove it you can remove the other trim.
Posted on Mar 22, 2009
snap101
snap101
  • 117 Answers
SOURCE: Can't remove the handle on Moen shower handle... Seriously!!!
heat it up with a torch, or just break it off, you can call moen at that point and kindly tell them that your handle broke and you need a new handle and cartridge. or you can get a drill and drill the allen screw out, they are such a pain i usually break them when i can get them out and get parts for it then
Posted on Aug 04, 2009
Anonymous
  • 334 Answers
SOURCE: My handle is loose but I cannot find a tool that
It would be an allen wrench. Any typical multi sized wrench should have the proper sized allen wrench.
The holes can often become filled with grime so be sure to seat the wrench properly to prevent stripping.
Posted on Aug 25, 2009
kgweis
  • 5 Answers
SOURCE: Remove belanger one handles shower faucet cartrige
its an "allen" head screw
Posted on Jun 24, 2010
How do i remove the faucett handle for a moen t2444nh monticello single shower handle
it may have build up from water and soap on white viniger will clean all the hard ater build up off in order to tiurn it
Dec 23, 2012 | Moen T2444NH Monticello 1-Handle Posi-Temp...
I am trying to remove the shower valve handle off a 20 year old unit. It has a chrome plated brass handle. When I removed the plastic cap off the front there was no screws attaching it to the valve. There...
Hi Denny--
It's a good idea to valve off the water to the fixture in question before you begin, as you can get wet doing this.
Inside that small hole you found should be an allen screw--of what size I am unsure. A standard-sized allen pack should have the size necessary.
Experiment by selecting the smallest available size, inserting it into the hole, and then trying to unscrew. If you don't feel anything catch, try the next size up.
Once loosened, the allen screw should come all the way out--be careful not to drop it down the drain!
With the screw removed, you should be able to remove the handle by pulling the handle gently away from the wall. Rocking the handle perpincularly can help, too.
If the handle has been on for a great while, more muscle may be necessary. Sometimes I sneak a flatblade screwdriver--wrapped in a cotton rag--between the handle and the wall plate and, with gentle pressure, pry the handle enough to loosen the bond between handle and control stem. Be patient!
Hope this helps,
Joe.
Jan 30, 2011 | American Standard One Handle Shower Only...
I have a three handle bath fixture...one for hot, cold, and the shower. My hot water won't shut off completely so im trying to take it apart to see if there is anything i can do. I took the cap off and the...
Yes,handle is just tight,put a small cresent wrench on end and try and wiggle back and forth-be careful,but should come off stem.Turn water off to house,(plus you might as well do cold side too.Should be packing nut underneath which is usually in wall,but you need to turn counterclockwise and pull stem washer will be there. hopefully in good shape.If not take to good hardware store and they can help rebuild,also they make a valve socket set to pull stems if there in the wall
Jan 26, 2011 | Home
We have a shower surround that is 1/4" thick. However, there is a void of at least 1" from the stud. Where do you mount the valve on the stud? Should it be in the middle or offset? We are...
can you get behind the surround?
Install it in the dead center of your cut out. Use 1x1x3" to support the piping behind your wall of the surround. silicone one side of each 1x1 apply to the wall between pipe and wall then use 1/2" copper "two hole straps/clamps" (any hardware guy will know this when you ask for them.) Use 1/4 - 3/8" drywall screws to fasten the pipe straps to the 1x1's. You'll get your stability when you install your escushtion (beauty ring) on the inside of the shower. Will tighten up against your 1x1's.
You'll see,
Enjoy,
Mike.
Ps. Plz leave a remark.
Dec 31, 2010 | Moen & One Handle Tub & Shower Faucet
I have a Moen shower faucet that is six years old(copper sweated plumbing). My wife noticed water dripping profusely from the downstairs ceiling during my shower. The screws holding the face plate were...
Try removing the handle, then the face plate. With a flashlight handy, check inside the wall around the valve to see if you see any leaks. Then, try the valve by pulling the stem (may need a plier to grab this). Keep checking inside the wall. Next, try the shower, and again watch in the hole you have. You may find that the connection(s) to the valve is/are leaking, particularly at the top of the valve where the shower pipe heads up the wall. Or, it may be that the shower head's arm is leaking somewhere above. If you only see water dripping down from above, try the flashlight with a small make-up mirror to see if you can see where it's coming from. Sometimes the pressure in the shower head builds up from the flow restrictor, or the head's spray holes may need cleaning out (try soaking the head in a solution of CLR [stands for Calcium, Lime, Rust] available at most home improvement/ hardware stores). Sometimes the shower arm (the bent 1/2" diameter pipe that the shower head mounts to) isn't fastened in tightly enough. A good trick to help here is to wrap the threads with teflon tape, then apply teflon paste also. Wrap the tape clockwise around the threads so that it doesn't unwrap when you screw the pipe back into the fitting in the wall. Also, make sure the threads in the fitting in the wall are cleaned out, and don't let any debris contaminate the new teflon paste as you slip it back through the hole in the wall. If you find that the pipe out of the top of the valve is leaking, I recommend you call the plumber. He/she can likely fix it without taking the wall apart.
Aug 27, 2010 | Moen & One Handle Tub & Shower Faucet
How do you tighten or remove handle on a danze shower faucet
Not to familar with faucet itself, but on most shower faucet's, there is a screw that holds it on. Most of the time there is a plastic face plate on the front of the handles, you pop that off and the screw is beneath, as you loosen you have to hold the handle in place, otherwise as you loosen the screw it will turn the water on.
Other fauet handles will have a set screw , usually on the bottom side of the handle body,( the part of the handle closest to the shower wall, either a small flat head or allen wrech should be all you need. good luck.
Jul 02, 2010 | Danze & Single Handle Tub And Shower...
The 8 inch handle of the frameless glass shower door is lose, wiggles and pops into the glass on the outside. The glassman just took off 2 little screws but said it it is rusted in place and wionf come...
well I would try to save the money,,
  • get new screws same size!!
  • get 4 o ring rubbers (same size of the handle)
  • get 1 tube clear silicon.
  • I guess you see where this is going..
  • stick the o rings to the base on the handle on eighter side..using the silicon (as less as possible)]
  • screw them back up..
May 04, 2010 | Home
How do you adjust the hot and cold on the shower. it wasn't working so my husband took out the screws on either side of the face plate, now hot and cold reversed
The cartridge just needs to be turned 180 degrees to put hot and cold on respective sides. As far adjusting temp., right behinde handle there should be two pieces bigger one goes in first. The smaller of the two is more ring like with a sqare on top, the more the sqare is rotated to the left, the more the handle can turn to the hot side of valve. I hope that makes sense.
Oct 03, 2009 | Moen & One Handle Tub & Shower Faucet
How do I remove the single faucet handle to replace it.
Mar 22, 2009 | Moen & One Handle Tub & Shower Faucet
Shower handle leak
turn off main water in home . turn on tap some where in home to release presser take shower handle off (screw under cap) unscrew the tap with a wrench unscrew on insides you pull out replace washer put all back togethere
Feb 11, 2009 | American Standard 3275.505.099 Colony Soft...
Home Logo
96 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
