Question about Home
I'm thinking it won't look all that great with the wall tiles coming down on top of the rocks...am using a schluter shower system. Thanks for any assistance! Denise
SOURCE: its possible to use a USB headset for Rock Band (Playstation 2)?
i don't think so about the headset but yes for the hsm sing it microphone
Posted on Jul 20, 2008
SOURCE: Toilet on uneven floor
I believe that I qualify... over 300 toilets installed in the past 15 months!!
I would go with the wax rings... but I would press the ring into the base of the toilet before installing the toilet....that way you are sure to have a good seal to the toilet....
If you actually read the directions, the manufacturer will tell you to press the wax ring onto the toilet....then install it onto the floor drain.
I guess that a PLAIN wax ring placed on the floor drain (since it is recessed) before placing the rubber-sleeve equipped ringed toiled is a good safety measure... I have done that an it work about 37 times out of 40.
Good question - BTW.. and well worded. THANKS for being specific and precise!!
Posted on Dec 31, 2009
Testimonial: "Sounds like a good idea. Not sure about the plain wax ring on the floor however. Doesn't this wax ring need a rubber sleave going into the drain?"
SOURCE: Walk-in shower floor problem
They probably use wrong adhesive that is not hard yet and have tenedency under pressure to squeze out between grout lines. Yes they need to address the problem immediately.
Posted on Feb 13, 2010
SOURCE: i bought a maax shower
There are two ways that I would do it depending on the width of the ledge on top of shower base. If you have enouch room I would shim studs with strips of material thick enough to bring the surface out even with flange on shower base. Then I would put cement board(wonder board) on wall and over shower flange to set on top of shower base. Finish seams on wall board per manufacturers directions,Let seam filler dry then seal with thompsons water seal or equivalent sealer. Let that dry then tile on that grouting and sealing with quality caulk at joint between shower base and tile.
If ledge on shower base is not wide enough then I would place cement board directly to studs then use filler strips on face of shower base flange to bring two surfaces flush. Water seal let dry and tile again coming down over top of shower. Grout and caulk to finish. P.S. I would use a siliconized latex emulsifier to mix in with grout. It gives a better ware proof seal. Hope this helps you. Good luck and thank you.
Posted on Jan 30, 2011
SOURCE: We can't get the machine to stop dancing across
are your loads sticking together causing uneaven spin cycle? or is there a bunch of heavy cloths that are not properly seperating?
Posted on Mar 06, 2011
Oct 03, 2015 | Home
Mar 06, 2015 | Home
Aug 31, 2013 | Home
Apr 23, 2011 | Danze & Single Handle Tub And Shower...
Jan 30, 2011 | Maax Acrylic Base for Shower - 102623
Nov 26, 2010 | Moen Plumbing
Jan 14, 2010 | Home
Sep 21, 2009 | Home
98 people viewed this question
