Hi Frank-
I found this link. How to change resolution on Roku TV.
https://video.search.yahoo.com/search/video;_ylt=AwrDQymKc91d5D0AaUD7w8QF;_ylu=X3oDMTBncGdyMzQ0BHNlYwNzZWFyY2gEdnRpZAM-;_ylc=X1MDOTY3ODEzMDcEX3IDMgRhY3RuA2NsawRjc3JjcHZpZAMxVTYuVURFd0xqRXlpaEVKWGFfVmpnRDJNVGd4TGdBQUFBQlVSVEFtBGZyA3lmcC10LXMEZnIyA3NhLWdwBGdwcmlkA00zeGl4elE2UmpLNlpKVEpsSHhXVEEEbl9yc2x0AzI4BG5fc3VnZwMwBG9yaWdpbgN2aWRlby5zZWFyY2gueWFob28uY29tBHBvcwMwBHBxc3RyAwRwcXN0cmwDBHFzdHJsAzI4BHF1ZXJ5A2hpc2Vuc2UlMjA1MHI2ZSUyMHJlc29sdXRpb24EdF9zdG1wAzE1NzQ3OTQxNTU-?p=hisense+50r6e+resolution&ei=UTF-8&fr2=p%3As%2Cv%3Av%2Cm%3Asa&fr=yfp-t-s#id=4&vid=dd4cc95e5d1a92c897a41293894a7f79&action=view https://video.search.yahoo.com/search/video;_ylt=AwrDQymKc91d5D0AaUD7w8QF;_ylu=X3oDMTBncGdyMzQ0BHNlYwNzZWFyY2gEdnRpZAM-;_ylc=X1MDOTY3ODEzMDcEX3IDMgRhY3RuA2NsawRjc3JjcHZpZAMxVTYuVURFd0xqRXlpaEVKWGFfVmpnRDJNVGd4TGdBQUFBQlVSVEFtBGZyA3lmcC10LXMEZnIyA3NhLWdwBGdwcmlkA00zeGl4elE2UmpLNlpKVEpsSHhXVEEEbl9yc2x0AzI4BG5fc3VnZwMwBG9yaWdpbgN2aWRlby5zZWFyY2gueWFob28uY29tBHBvcwMwBHBxc3RyAwRwcXN0cmwDBHFzdHJsAzI4BHF1ZXJ5A2hpc2Vuc2UlMjA1MHI2ZSUyMHJlc29sdXRpb24EdF9zdG1wAzE1NzQ3OTQxNTU-?p=hisense+50r6e+resolution&ei=UTF-8&fr2=p%3As%2Cv%3Av%2Cm%3Asa&fr=yfp-t-s#id=4&vid=dd4cc95e5d1a92c897a41293894a7f79&action=view
Hope this helps.
SOURCE: black borders
Check the resolution settings on your cable box, you may have to call your cable provider to find out how to get into the settings menu, there is a stretch function in the settings that should make all the lower channels auto fit your screen, also see if there's a p=size button on your remote control, try pushing that when on the channels that have sidebars.
SOURCE: New Samsung Plasma HDTV
That is what is called BURN IN or as the manufactures call it "IMAGE RETENTION". Basicly what this means it that you have been putting more hours on the part that is darker the smaller part, or the 4x3 picture or the square part. And, basicly the part that appears to be lighter is "LESS" worn out than the other part of the plasma tv. There is no fix for the problem, But if you go into the menu and select "BURN-IN" OR "Pattern sweep" or WHITE Screen than you will see exactly what i mean. Now, you can keep it on this pattern overnight if you would like, but i suspect it will not cure the problem, but lessen the effects of it. But keep in mind, you are reducing the life of the complete panel when you do this. Not that it is bad to do this. If you have anymore questions don't hesitate to ask anymore questions. The better fix is to Switch over to the "Dish Network and than you can format the screen on any channel in any mode. Superior product to cable. Have a great day. And watch out for the snow storm coming. GURU JAY
SOURCE: DVD Plays in Black and White
Depending what cables you have, try plugging only the yellow cable into "video out", I previously had red, white, and yellow cables plugged into "comopents out" and only got black and white. Doing only the yellow into video out gave me color.
SOURCE: Tv turns on cable is in tv,but no cable or anything black screen
First is the cable active? If so make sure all cables are connected propperly from the outside sorce to the tv. If all of the above are ok check the remote menu to make sure that it is acsessing the correct inport source:cable,antenna,hdmi,etc. Also with the change over to digital you may have to have the tv rescan all availlable channels.
SOURCE: My hisense 50 inch lcd tv has picture but no sound.
If you still have back light, then the T-con is probably defective. If you don't have back light, then you either have a bad power board/inverter or a defective panel
