Error message 457 on my ricoh af4106 copier - Office Equipment & Supplies
  • 5 more comments
  • Anonymous Sep 19, 2009
    Ok, I am an idiot here. I got this copier used, (Though nearly new) Brought it back to the office today, set it up and started running it...worked fantastic for about 500 copies, and now this message. I am mechanically inclined, and have an associate who is as well, but this is a new piece of equipment for me, and I don't know what I am looking at. I am sure your answer will completely solve our problem, but, can you give me a bit more info?
    Ok, so I have service code 457 on my ricoh 4106...I just got the thing today, but it is used and I know nothing about it. Can anyone give me a bit of guidance as to what I am looking at? THANKS!!!
    SC it is, and that sounds simple enough....now can you explain that to a dumbell like me...
    What is it and how do I clean it???
    Let me give you a bit of back story here...I bought this copier used, and picked it up today. The previous owner has not had it long, but was sent another by their corporate office, to be all compliant...It was printing beautifully and everything on it looks in great shape, but all of a sudden I got a 1" square printing on all of my copies, and then this message. I am not a computer person, but am moderately proficient with mechanics. I am pretty certain that this is a simple fix, and I don't have the money for a repair, so I am really hoping I can do this myself. How complicated a repair is this?? Is it something a layman can do? I REALLY appreciate your help!!! Darla
    OK, now I think I might be getting somewhere...One last stupid question...How do I get to it to get it out???
    Thank you for being so patient!!
    Ok, you say "complete steps to open door." I assume this means I am not just popping off the cover like I would to clear a paper jam? What door am I opening and how do I do it.
    (Did I mention that I am new at this, and apologize for being a pain in the neck yet???)
    Again, thank you so much for your time and patience.
    Darla
  • Anonymous Sep 20, 2009
    Your solutions have been great, only one problem I have now is I don't know how to open the Ricoh Aficio 4106 for repairs to the belt.
taran_2005
  • 10,515 Answers
On these copiers, there must be 2 alphabets before 457 as well.If it's SC457, the description is as below :-
Error Code Sc 457 :- Image transfer Belt cleaning, Unit position error.
The above one is self explanatory what you need to do in order to fix this.
Any further assistance, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 19, 2009
Testimonial: "Extremely helpful and responsive. Gave detailed, instructions and was friendly and professional. Excellent service."
  • 1 more comment
  • taran_2005
    taran_2005 Sep 19, 2009
    Thanks for your response!!
    If we talk about Image transfer belt cleaning - After a certain point, the transfer belt may be worn or covered in toner.
    This belt will occasionally need to be
    replaced. Try reseating it first. Remove the imaging drum unit ( the
    housing that holds the 4 toners ). The transfer belt is the unit behind
    the drum that is inserted along the top edge of the drum cavity. It can
    be a little tricky to get it in there correcty. Kind of hold it up
    against the top of the cavity as you slide it back towards its holder.
    If it looks worn, it will need to be replaced.
    Unit position error - Try unplugging the copier for few minutes and then again plug in the copier.Make sure the position of the print head is all set. Check drum and other parts to make sure everything is all set.
    If unable to fix, then you need to call Ricoh for replacement or for repair.
    Hope i helped you.
    DO ACCEPT THE SOLUTION IF 100% SATISFIED.
  • taran_2005
    Thanks for your patience!!
    It's not difficult but tricky. You need to open your Copier and clean the transfer belt. This is how transfer belt unit looks like :-
    http://www.precisionroller.com/img/J4084...
    You need to clean them. If the problem persists, then you need to contact ricoh.
    Note - The best product for cleaning transfer belts is
    something called Bestine. It is a rubber cement solvent and is found in
    art supply stores. Excellent product as it even works on toner
    cartridge drums.
    Any further help, let me know.
    Hope i helped you.
  • taran_2005
    I can offer a generic solution. You might need to adjust as per your model and i hope it would not be a difficult task.
    1. Make sure that the printer is turned off.
    2. Turn off or unplug any optional devices to the copier.
    Warning - Do not touch, drop or place anything on the transfer belt. Touching the surface of the transfer belt or placing items on it may cause damage.
    3. Complete the steps to open the door.
    Note - Inside of the Copier may be hot. Allow the copier before touching.
    4. Loosen the thumbscrews on each side of the transfer belt cover.
    5. Lift and remove the transfer cover belt.
    6. Loosen the thumbscrews on each side of the transfer belt.
    7. Pull the transfer belt out.
    8. Clean/ replace the transfer belt.
    9. Align the transfer belt with the opening of the copier.
    10. Slide the transfer belt in it until it is fully seated.
    11. Tighten the transfer belt thumbscrews.
    12. Align and place the transfer belt cover as it was earlier.
    13. Tighten the transfer belt thumbscrews.
    14. Lift and remove the 4 shipping spacers from the transfer belt.
    15. Close the top cover and the front door.
    16. Reconnect the optional devices to the printer.
    17. Turn the optional devices on.
    18. Turn the printer on.
    I HAVE A VIDEO NOT FOR YOUR MODEL BUT WOULD HELP YOU IN UNDERSTANDING HOW THE TRANSFER BELT LOOKS LIKE.
    http://www.youtube.com/watch?v=wv_uNjttG...
    Hope i helped you.
lyzias morato
    President:
  • 1,566 Answers
Hi!
This information might help you.
SC457 Position error for the image transfer belt’s cleaning unit
- Timing & Condition
• When the belt cleaning section touches the image transfer belt, but the belt cleaning sensor signal remains LOW.
• When the belt cleaning section releases from the image transfer belt, but the belt cleaning sensor remains HIGH.
• Dirty Sensor
• Defective sensor
• Defective belt cleaning shift clutch
• Defective drum peripheral component motor
• Defective I/O control board
• Defective main control board
1. Pull out and re-insert the image transfer
belt unit.
2. Clean the image transfer belt cleaning H.P. sensor.
3. Replace the sensor. (Input Check: 5-803- 012)
4. Replace the belt cleaning shift clutch. (Output Check: SP5-804-036)
5. Replace the drum peripheral component motor.
6. Replace the I/O control board.
7. Replace the main control board. [Signal Check]
• H.P.: CN219-B2 or TP108 on the I/O
control board
Testimonial: "Detailed answer to the question, but technical...I don't know much about the machine, so the answers were above my head. "
Dennis Kierulf Ordinante
  • 404 Answers
Hi marketing292! I will be glad to assist you in your concern.. pls do the following.
Turn the main power of the device off and on again.
If some parts or supplies were replaced recently, try removing them, replacing them again, and then turning the main power of the device on off and on. (If the device is interpreting imperfect parts detection as an error.
The device might be interpreting extreme changes in temperature as an error. Turn off the main power switch, wait for a few minutes to cool it off, and then turn it on.
Note that "main power" means the actual, physical power switch.
If the problem still exist, please contact your local service representative or original point of purchase.
Posted on Sep 20, 2009
Anonymous
    Scholar:
  • 149 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is a transfer unit position error.
Remove the transfer faceplate. Put the ransfer faceplate back on and
turn the knob tight. While pushing the upper left corner of the
faceplate (pressing on the revolver/drum drawer), tighten the screws.
Tighten up the knob some more until
the drum starts turning too.
Ricoh Aficio 2232C Error Message SC393-02
I had the same problem after transit of copier. Try removing the yellow developer unit and give it a good shake. You may need to do it with the other units too.
Apr 16, 2013 | Ricoh Aficio 2232C Color Copier
Ricoh 6513 Error Code Sc.387 Error Code Sc.457 Error Code Sc.350
1. Set SP3-125-003 to a value of
2 to enable Job End & Non-use
3 Self Check Mode.
fore more hrlp visit https://cbrtechsolutions.net
Jan 21, 2011 | Ricoh 6513 Copier
Ricoh Aficio 2035 wont duplex, displays error message error: Duplex unit is not set. Set it properly
there is a sw on the duplex unit that tells the copier it is closed my guess is that its broke
Nov 04, 2010 | Ricoh Aficio 2035 Copier
HOW WILL I SOLVE PROBLEM OF E5 ERROR MESSAGE IN RICOH 4018 AND E11 ERROR MESSAGE IN RICOH 4622 PHOTOCOPIER
e 5** fuser related temperature over/under
e1** optics related
both need service engineer
Oct 04, 2010 | Ricoh Office Equipment & Supplies
Ricoh colar 6513 cod sc 457
SC457 mean Image Transfer Belt Cleaning Unit Position
Error, try to clean the sensor in the transfer belt with a dry cloth.
Jun 21, 2010 | Ricoh 6513 Copier
Error message of Sc 725 Ricoh copier
Description:
Finisher stack feed-out motor error
Symptom:
The stack feed-out belt HP sensor does not activate within a certain time after
the stack feed-out motor turned on.
Possible Cause:
Stack feed-out HP sensor defective
Stack feed-out motor overload
Stack feed-out motor defective
Aug 25, 2009 | Office Equipment & Supplies
Hi I have Ricoh Alficio 2032 copier. There is C545 error message
I'm assuming it's SC545. It pertains to temp not being correct in the fuser. Possibly a thermistor, thermal fuse or lamps are bad. It's one of the codes that need to be troubleshot and replace whatever is needed before clearing the code. This is to prevent further damage to the machine. Thanks Colin
Jun 28, 2009 | Ricoh Office Equipment & Supplies
Error Box on Scree with Error SC-545
Hello sir; According your message, I guess your copier should be Ricoh, any way need to reset your machine, just follow following steps;
1, press "clear mode", "107", and hold down "clear/stop" key until screen change message.
2, turn power off and back on,machine should be in working now.
May 29, 2009 | Ricoh Office Equipment & Supplies
Error code sc 172 on ricoh aficio 2103
Hello sir; This error code is indicate video process error, may be can be reset, the procedure as follow;
press "clear mode", "107", then press and hold down "clear/stop" key for about 3 sec., until SP menu display, touch "copier sp" on screen, enter 581002 then press 1, then turn power off and back on. see what's happen. good luck !
Feb 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh aficio 200
Ricoh Aficio 200 copier has stopped copying from side tray. Can you help?
[email protected]
Feb 17, 2008 | Ricoh Aficio 180 Laser Printer
153 people viewed this question
jasbo
jasbo
Marvin
Marvin
