SOURCE: Massage chair fuse on it keeps blowing Model iRest SL-A08-3L
Get its PCB checked for any shorting or ask a technician to brush up the whole pcb with some alcohol and try 5A fuse instead of 4A. You can also look for latest Jade massager bed Carefit 5000 which is more advanced than a massage chair
SOURCE: Can I use an electric massage chair when I'm pregnant?
There is no overt problem with using a massage chair when pregnant. If you are comfortable then use it. You and the baby will be fine. If you'd like to read more about massage chairs and pregnancy, check out this article...
http://www.massage-chair-relief.com/blog/general/can-massage-chairs-be-used-when-pregnant/
Hope this helps!
SOURCE: Massage chair national real pro 110 volts was put into 220 volt. Where can i see the fuse ?
Search Results
replacing that AC/DC converter : voltage divider ? ' Electronics ...
www.electro-tech-online.com/.../replacing-that-ac-dc-converter-voltage-...
Jan 23, 2012 - 6 posts - ?4 authors
we purchased a massage chair from china , shipped to my home . my sister -guided ... being the home electronic "pro" ( lolz i don't know any real **** about ... it into 220vbroke it. i found the fuse to be burned. ... 110v AC inputMissing: national
