Step 1
Turn off the shower light at the light switch.
Step 2
Place a rug with a rubber backing in the shower stall for secure footing. Place the step stool on top of the rug.
Step 3
Insert a plastic putty knife between the outside rim of the light fixture and the ceiling. Be careful not to scrape the finish off the ceiling when inserting the blade.
Step 4
Pry the fixture cover away from the ceiling with the putty knife. The fixture cover includes a translucent plastic lens within a metal rim. The cover is held in place by torsion springs, so it will be resistant to release. Apply careful pressure until the cover pops off.
Step 5
Remove the old light bulb, and replace it with a similar bulb.
Step 6
Press the cover back in place. The torsion springs will click into place when you press the cover into the ceiling.
Posted on Dec 09, 2019
SOURCE: How to remove cover in shower fan/light
I tried turning my light fixture counter clockwise but that didn't work. I tried the screw driver technique as well, but that didn't work either. However, I applied pulled down the whole fixture with steady, even pressue on both sides and that did the trick. The fixture comes down a few inches while sliding on two wire guides on either side.
Posted on Jul 09, 2009
Feb 21, 2014 | Moen 3175 Legend One Handle Shower Faucet...
Aug 13, 2013 | Televison & Video
May 19, 2013 | Grundfos Pumps Grundfos MQ 3-45 1 HP...
Mar 31, 2010 | Delta & Single Handle Shower Faucet
Jan 13, 2010 | Dometic Rooftop RV Air Conditioner
Sep 19, 2009 | Home
Dec 30, 2008 | Heating & Cooling
112 people viewed this question
