Question about Home
Initial time setting. How do you sync time and chime?
SOURCE: seiko mantle clock (switchable chimes)
See this site
http://www.theclockdepot.com/seiko_westminster_clock_instructions.html
Posted on Apr 22, 2009
SOURCE: I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMIN
Manually turn the minute hand forward until the 16 westminster chimes sound and then the hour strikes. Then remove the minute hand (it will go on in four positions) and put it back on at the 12 o'clock position. The chimes should now be back into sync.
Fred
Posted on May 10, 2010
SOURCE: Elgin Westminster Quartz Chime clock won't work
IF I GATHER CORRECTLY , YOUR CLOCK HAS TWO BATTERIES, ONE AT BASE AND ANOTHER ON THE BACK OF THE UNIT. THE ONE ON THE BACK OF THE UNIT IS RESPONSIBLE FOR CLOCK'S FUNCTIONALITY AND I THINK THE BATTERY AT BASE IS FOR THE ROTATING BALLS ( PENDULUM ). SO OPEN UP THE BACK IF YOU HAVE NOT DONE SO, AND REPLACE THE BATTERY. CAREFULLY THOUH AS THERE RE TWO SCREWS ON TOP AND A SNAP AT CENTER BOTTOM WHICH YOU COULD EASILY BREAK IF YOU DO NOT DO IT WITH CARE. OPEN UP THE SCREWS FIRST AND GENTLY USING A SCREW DRIVER PUSH BACK ON THE SNAP HOLE TO FORCE IT UPWARDS AND INWARDS. IF NONE OF THIS MAKES SENSE THEN WE ARE LOOKING AT TWO DIFFERENT CLOCKS.
HOPE THIS HELPS.
Posted on Oct 11, 2010
SOURCE: Elgin Anniversary clock chimes early
take the big hand off and move it back one square on the shaft
Posted on Nov 12, 2012
Apr 19, 2018 | Home
Oct 31, 2015 | Cars & Trucks
Jun 20, 2015 | Bulova Collins Majestic Triple Chime...
Nov 08, 2014 | Home
Jul 13, 2012 | Watches
Apr 30, 2010 | Seiko Mantel Clock
Apr 24, 2010 | Seiko Mantel Clock
Apr 05, 2010 | Seiko Mantel Clock
Jun 19, 2008 | SkyScan 86709 Atomic Wall Clock
138 people viewed this question
