Question about Lands Phones
Question...* what turns do not disturb off - Lands Phones
Posted by Mike Sinclair on
Reset Do not disturb
Question is kind of Vague, so I'm assuming you are trying to turn off the Do Not Disturb (DND).
In the standby mode, press the do not disturb button on the base. The DND indicator will light and DO NOT DISTURB shows in handset display. To cancel, press the do not disturb button again.
Hope that helps.
Sep 18, 2013 | GE Dect 6.0 Phone Digital Answering...
When someone calls messae says' not accepting calls' how do i turn this off
Does this happen on all inbound calls or just some?
If this is on all inbound calls...Sounds like Do not disturb is turned on. Most uniden's have a DND (do not disturb) mode. Try turning this off and see if that helps.
Using Do Not Disturb
  • The Do Not Disturb or DND feature turns off the audio ringers of the base and all handsets at the same time. It does not affect any of the visual ringers.
  • With the phone in standby, press and hold Do not Disturb on the base. The phone automatically turns on the answering system and shows Do Not Disturb in the display on all handsets.
  • To cancel, press Do not Disturb.
If this is not the issue, it may be turned on at the central office (your phone company) try using the DND activation/deactivation code of *64 from your phone.
If this is just on some inbound calls...Then it you may have anonymous call rejection turned on. That feature blocks calls from people that block their calling number when placing calls.
Mar 01, 2012 | Uniden DECT 6.0 Cordless Phone ID
Program "Do not disturb" on business phone
It's pretty straightforward. You pick a spare button, dial FEAT 00 press the blank button (with a light) and press FEAT 01. There are considerations that I'll reproduce here.
Do Not Disturb (F01) 8
Use this feature to be able to press a programmed button to prevent incoming calls for the
extension from ringing (lights still flash). When Do Not Disturb is on, outside callers hear ringing
while inside callers hear a busy signal. You should use Do Not Disturb only if someone answers
outside calls for your extension when you do not answer them.
Considerations 8
Do Not Disturb is available only on system telephones.
Do Not Disturb requires a button with lights. When the Do Not Disturb feature is on, the light
is also on, indicating that the telephone will not ring.
■ Use Do Not Disturb when you do not want the auto attendant or the voice messaging system
to transfer calls to you.
■ Use Do Not Disturb if you are assigned to a Hunt Group and you leave your desk, so calls to
the Hunt Group will skip your extension and ring immediately at the next available extension
in the group.
■ To avoid missing calls when Do Not Disturb is not needed, turn it off.
■ If Do Not Disturb is active at a doorphone alert extension, the person at the doorphone hears
signaling, but the alert extension is not signaled.
■ Unanswered calls that are transferred from an extension with Do Not Disturb active ring at
that extension if they transfer return.
■ Extensions with Do Not Disturb activated do not receive Caller ID information, unless the call
is answered.
■ Users with Automatic VMS Cover Assigned or with VMS Cover turned on can activate Do
Not Disturb
to Send All Calls immediately to their voice mailbox.
■ Users with Call Coverage turned on can activate Do Not Disturb to Send All Calls
immediately to the covering extension.
■ You cannot use Call Screening (F25) when Do Not Disturb is turned on.
Carl
May 10, 2010 | Lands Phones
From the manual: You need to program a button with FEATURE 01.
¦ Use Do Not Disturb when you do not want the auto attendant or the voice messaging system
¦ Use Do Not Disturb if you are assigned to a Hunt Group and you leave your desk, so calls to
in the group.
¦ To avoid missing calls when Do Not Disturb is not needed, turn it off
Carl
Mar 16, 2010 | Lands Phones
Phone set on do not disturb can not undo
For GE 6.0: There is a button on the base (NOT the phone), you need to press it once again to turn off Do Not Disturb
For GE 5.8 GHz: 1. Pick up the phone handset and dial *98.
2. Press 2 to disable Do Not Disturb.
3. Once you hear the confirmation that Do Not Disturb has been disabled, you may hang up the phone handset.
Nov 12, 2008 | Uniden Cordless Phone
Do not disturb is on and i dont know how to turn it off
For GE 6.0: There is a button on the base lower right corner  (NOT the phone), you need to press it once again to turn off Do Not Disturb
For GE 5.8 GHz:
Oct 24, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
PHONE WILL NOT RING
on the phone i used to own i would have to press and hold the do not disturb button and it would beep telling me that that feature was turned off.....try it and let me know
Sep 28, 2008 | Uniden Cordless Phone
Taking off Do Not Disturb
For GE 5.8 GHz:
Hope this helps!
Aug 04, 2008 | Uniden 5.8GHz Dual Cordless Phone
Do not disturb
For GE 5.8 GHz:
Jan 02, 2008 | Uniden Cordless Phone
Comdial Impact 24/48/72 phone
You can try the below steps in order to turn off Do Not Disturb. For GE 6.0: There is a button on the base lower right corner  (NOT the phone), you need to press it once again to turn off Do Not Disturb
For GE 5.8 GHz:
Nov 01, 2007 | Comdial 8324S-PT Corded Phone
Lands Phones Logo
93 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
