Question about Philips Televison & Video
Philips tv model 42PFL3704D/F7. I plug it in and the power LED comes on for about 6 to 8 seconds then shuts off. Power button does not turn it back on. No picture on screen.
Posted by Ronald J Peters on
Larry
  • Philips Master
  • 3,589 Answers
This model has issues with the power board
Posted on Nov 01, 2021
5 Related Answers
Anonymous
SOURCE: TV shuts down
Remove the lamp assembly, There will be a screen on the top and bottom of the assy remove all dust from these screens. also check the tube at the top of of the lamp receptical this is an air cooling pathway. reassemble and fire it up. This worked for me and saved some serious coin judging from some of the other solutions I have seen (lamp and balast) ouch!!!
Posted on Jul 06, 2007
Anonymous
SOURCE: Turn on power, but no picture, when you turn off power see picture for a few seconds before tv shuts off
Even, I have the same problem...looking for a help on internet but not finding any...if you know...please post on this site.
Thanks,
Posted on Jan 13, 2008
Anonymous
  • 505 Answers
SOURCE: Philips/Magnavox TV, model MS3250C321 shuts off randomly.
TV shutting off automatically means its a problem with the Lamp. Contact Pioneer or any local tech shop or Best buy and get the same replaced.
Turning off after specific time : Go to the timer option and disable the Automatically Switch off option. This will resolve the issue. Please let me know if it worked. If you need the user manual or instruction manula please click on the link below
http://www.generalmanual.com/Televisions/Sanyo-DP19647-Wide-Screen-Integrated-Digital-LCD-HDTV.htm. Hope this will be of help to you.
Thanks
Posted on Oct 17, 2008
Anonymous
  • 187 Answers
SOURCE: seems as if LCD screen is not recieving any power, I have no picture or sound right now but can faintly hear speakers power up when I turn the unit on.
Mainboard damaged.
Posted on Jun 02, 2009
Anonymous
  • 458 Answers
SOURCE: Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Posted on Oct 02, 2009
Philips 42PFL3704D/F7. Why does it keep restarting?
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Oct 9, 2012 - 5 posts - ‎2 authors
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable attached ... or Cable TV to unit the power resets, philips screen comes on and keeps on resetting. ... I tried a cable to the tv without the box and I do get picture.
Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV
www.amazon.com/Philips-42PFL3704D-F7.../B001LP...
Amazon.com, Inc.
Rating: 3.3 - ‎50 reviews
Amazon.com: Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV: Electronics. ... Will do all I can to prevent others from getting ripped off by Philips. ... came up every few weeks and would take an hour or so of reset before working properly.
Visit the support page for your Philips LCD TV 42PFL3704D ...
www.philips.ca > philips > Televisions > 3000 series
PhilipsFind support for your LCD TV 42PFL3704D/F7. ... How do I output sound from myPhilips TV to external audio devices such as Home Theaters, Soundbars, AV ...
42" Philips 42PFL3704D/F7 LCD TV WON'T COME ON - A
1helpful
Philips 46PFL5706/F7 46 LCD TV. When you turn it on you have power. The Philips logo appears for a second then goes away. Screen is black after that.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Philips 52pfl5704 no screen image
Sounds like main board fault. Contact the authorized service center for Philips. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Back ight
Yes, this TV has back light. This is a part of the energy saving and adjustable by the initial setup menu.
Philips tv will not turn off
So it won't turn off via remote or side buttons?
2helpful
2answers
Where is fuse on philips model 42PFL3704D/F7
the fuse should be on the power supply board...it looks like a inch cylinger with metal caps....it's super thin filament too ....
2answers
We recently got a Philips 42PFL3704D/F7 lcd tv. We have our computer hooked up to one of the HDMI channels, and we have a switchbox hooked up to the 'Component' channel. The switch box does TV and our...
I had this a issue with the Component input not working right as well. I had a repair tech come to my house to take a look on Philip's dime. Turns out it's the main circuit board. You cannot obtain this part from Philips. I've been in a fight with Philips to replace the TV. All this started in Aug 09.
Televison & Video Logo
Top Philips Televison & Video Experts
 Francisco Mauricio...
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
