Question about The Office Equipment & Supplies
0xc18a0a02 keeps coming up and won't let me print need to know whats the problem
Posted by Georgia L.... on
4helpful
My Pinnacle Pro 901 is set to print using black ink only but it keeps telling me I need to replace color cartridges and won't print.
You won't be able to print if one of the cartridges is out of ink. The printer needs all cartridges with sufficient ink levels to prevent damaging the printhead.
Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
1helpful
I need to know what size power inverter in watts and if they come with a car lighter plug
You won't do it. An inverter will keep a compressor running at maybe 200 or 300 watts but it won't start it up.
May 17, 2012 • Freezers
I want to print using my lexmark X6170 but I don't want to print color so I didn't put a color cartridge in. It keeps coming up with an error message and won't print at all.
Some printers require you to have the color cartridges in them even when you are printing black and white. You usually can in your print options choose black and white over color.
Power is connected and printer is on; printer cables to pc is connected however this message keeps coming up to check them....and the print wont print....what can I do?
It could be a driver problem where the computer system won't able to detect the hardware completely. Try installing the driver of your printer and try using other ports if it is a USB one.
Canon MP470 keeps telling us the ink cartridge needs to be replaced and it won't print. We keep replacing the cartridges but this error keeps coming up. Very frustrating. Can you help?
First May be the Cartriges you bought is not original.second If they are original they clean your printer with air blower.May be it works.Just Try
I have a HL4040CN copier. When the message comes up that ink is low, how can I tell what color ink cartridge needs replacing
You're just going to have to keep printing until you see which cartridge is getting dry. It'll be either the black one or the colour one. This way you won't buy the wrong cartridge. If you print black text and it starts to come out grey then it's the black cartridge that needs to be replaced. The same with colour, if the picture looks faded then you'll need a new colour cartridge.
2answers
Hi my canon fax-jx200 keeps coming up recorded in memory..How do I retrieve it?? Many thanks, Lorraine
Hi Lorraine,normaly with this fax it have a auto print off setting that keep the faxes in memory.You can turn auto print to on by pressing the on/off button once less than a second,then it will switch to auto print on.
Let me know if you dont succeed.
NO PRINT HEAD
First remove cartridges and remove print head and make sure the contacts on back of head look clean. I use fibreglass pen and give clean if in doubt.But be very carefull cleaning. But maybe not seated correctly.? If you pull the print head out and do another test does it come up with same message.?
Try again and see what you get. Still worth replacing head if faulty as where else can you get a 8 ink printer. Unsure what head costs.
Top The Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Pieter Vleeshouwers
Pieter Vleeshouwers
Jean Thiebaux
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
