Question about Boating
Is a 1971 evinrude Model18102SC a short or long shaft
Posted by Bill Candy on
Evinrude year serial number. 6102e-J03277
1971 6 HP, It has to be 2 cycle. 50:1 premix. Great little motor.
Aug 15, 2014 | Light Outboard Motor Boat Bass Fishing...
Need to see the assembly differences on a evinrude 35 hp (1978) long shaft and short shaft. I am changing my long shaft to a short shaft and there is a tube that I don't know the purpose of.
Try going to: http://shop2.evinrude.com/Index.aspx?s1=gett3uheq5c0nce2mjg11d1eh0&catalog_id=0&siteid=1
There you can search out all differences. You will need year, make and model # of your engine.
The tube is probably a water pump alignment tube to insure the water pump tube goes into the water pump since its not visible during installation.
Oct 06, 2013 | Boating
Removing the lower unit on a 1992 Evinrude short shaft 50 hp
Under Lower Carburetor is a Bolt Going Through The Shift Rod Remove This Bolt--Then Undo All Bolts Holding The Lower Unit--The Lower Unit will Then Come Out Don't Turn The Shift Shaft As It Is Threaded And Will Change The Set Length,If You Do Have To Remove It Then Crew It Fully In Counting The No Of Turns So That You Can Set It Back To The Original Position
Good Luck
Mar 23, 2013 | Boating
1964 5 1/2 hp evinrude kills at high speed
You should have a High Speed carb adjust and a Low Speed carb adjust. If it's running fine while idling, adjust the high speed setting. If you have two nobs, its the lower one. May be set wrong. If you don't have two nobs, remove the carburator and check the jets to make sure they are completely clean or better yet, order yourself a carb rebuild kit to take care of all of this. I just rebuilt my 1971 evinrude 4hp and the carb kit made the world of difference.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/matthew_d24b835e574ef6ca
Apr 17, 2010 | Light Outboard Motor Boat Bass Fishing...
Where does the water exit a 1971 25 hp evinrude? how do I know it's pumping water?
I do believe the water jets are down on the lower unit by the prop. There should be a white swirl of white bubbles shooting out.
Apr 16, 2010 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
111 people viewed this question
Top Boating Experts
ray gallant
Andrew Taylor
Andrew Taylor
Bill Boyd
Are you a Boating Expert? Answer questions, earn points and help others
