Question about GPS
How do i change GPS co ordinates in xgody 704 please
Posted by Carolyn Eden on
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: GPS displays BNG on location
BNG stands for 'British National Grid'
  1. Go to the Setup menu
  2. Select Units
  3. Change the Position Format to hddd°mm.mmm'
Posted on Jun 24, 2008
Anonymous
  • 83 Answers
SOURCE: Garmin GPS 12 seems to be a few hundred yards out!
Go into your device and pull up the setup section. There should be a selection that needs to be checked called WAAS. When that is selected your accuracy should be +- 3 meters if I remember correctly. At any rate it will be much more accurate.
Posted on Apr 02, 2009
TO Lady
  • 638 Answers
SOURCE: Garmin eTrex HC GPS Location settings set to TL
Owner's manual Page 42
Setup > Units > Position Format
Please come back and tell us if this fixed your problem, and rate our solution. Thanks.
Posted on Jan 04, 2010
Testimonial: "Thank you so much. I looked and looked through the manual and had actually played with that particular setting but didn't realise it. Thank you."
Anonymous
  • 65 Answers
SOURCE: what do you think is the main co-ordinating
moneyomatic is a game were you cout money and earn money
Posted on Dec 25, 2010
Lohith Arcot
  • 126 Answers
SOURCE: My touch screen is not
go to settings and search for word screen calibration. click it and tap exactly where the mobile says you to.now you will be able to use flawlessly.And please do vote with the thumbs up symbol below.Thank you
Posted on Jul 19, 2011
Free manual xgody dash cam
Search results for: 'user manual xgody' - xgody.com
www.xgody.com/catalogsearch/result/index/?q=user+manual+xgody
XGODY Y10 Plus 6.0" Unlocked Android 5.1 4Core 2SIM 3G Mobile Phone Smartphone 1+8GB New Gold. XGODY 10.1'' INCH Tablet PC Android 4.4 Dual SIM 3G GPS Quad Core 16GB WiFi HD. ... XGODY 5" Car Truck GPS Navigation Navigator SAT NAV 8GB HD Display Free Map POI.
www.xgody.com/catalogsearch/result/?q=user+manual+xgody XGODY 6 Zoll unlocked Smartphone Handy ohne Vertrag 2 SIM 4Cores 8GB 8MP GPS Y15. Add to Cart Add to Wishlist Add to Compare · XGODY HD 7"TRUCK CAR GPS Navigation FM 8GB Touch Screen SAT NAV With Sunshade XGODY HD 7. $66.16 ...
www.xgody.com/catalogsearch/result/index/?dir=desc&order...manual+xgody XGODY 3'' HD 1080P Car Vehicle Dashboard DVR Video Camera Recorder Dash Cam HDMI. Add to Cart Add to Wishlist Add to Compare · XGODY 7" Car Truck GPS Navigation SAT NAV 8GB Lorry Navigator Free IG BT & XGODY 7. $72.17 ...
www.xgody.com/catalogsearch/result/index/?cat=142...manual+xgody 1x BAOFENG UV-6R Walkie-Talkie 2-Way FM Radio Transceiver Dual Band 128CH 7Watt. Add to Cart Add to Wishlist Add to Compare · XGODY HD 1080P 7" Car DVR Dual Lens Rear Camera Dash Cam GPS Bluetooth 3G XGODY HD 1080P 7. $100.99 ...
www.xgody.com/catalogsearch/result/index/?dir=desc...15...manual+xgody XGODY 3'' HD 1080P Car Vehicle Dashboard DVR Video Camera Recorder Dash Cam HDMI. Add to Cart Add to Wishlist Add to Compare · 10.1" Unlock 3G Phablet Dual Cams Sim Card GPS Bluetooth WIFI Google Android 4.4 10.1. $134.93 ...
manual xgody dash cam Google Search
Apr 30, 2018 | Cell Phones
I need user manual for smart phon XGODY model X17
read your manual. Search results for: 'xgody 7 in GPS model 704 instruction manual' ... not sure if this is what you are looking for. Manual xgody ...
XGODY X200 Smartphone
Jun 10, 2017 | Cell Phones
I want my xgody to speak saying miles insead of kilometer
read your manual
Search results for: 'xgody 7 in gps model 704 instruction manual'
www.xgody.com/catalogsearch/result/?q=xgody+7+in+gps+model+704...manual
Search results for 'xgody 7 in gps model 704 instruction manual' ... XGODY Y10 Plus 6.0" Unlocked Android 5.1 4Core 2SIM 3G Mobile Phone Smartphone 1+ ...
Search results for: 'xgody 7 in gps model 704 instruction ... - xgody.com
www.xgody.com/catalogsearch/result/?cat=16&mode...xgody...gps...manual Search results for 'xgody 7 in gps model 704 instruction manual' ... XGODY 7" Car Truck GPS Navigation SAT NAV 8GB Lorry Navigator Free IG BT & XGODY 7.
www.xgody.com/catalogsearch/result/?cat=128...list...xgody...gps...manual Search results for 'xgody 7 in gps model 704 instruction manual' ... 7" XGODY Car GPS Navigation Lorry Coach Truck Navigator Nav 8GB POI Speedcam 7.
www.xgody.com/catalogsearch/result/?cat=40&mode...xgody...gps...manual Search results for 'xgody 7 in gps model 704 instruction manual' ... XGODY 7"HD 8GB Portable Truck Loryy Car GPS Navigation Bluetooth AV-IN+ XGODY 7.
XGODY GPS Navigation User Video - YouTube
? 2:07
https://www.youtube.com/watch?v=E2dcy3kGLSc Jan 13, 2015 - Uploaded by XGoDy Electronics
This is the Brand XGODY GPS Navigation User Video,it shows you how to install the GPS to the Car,the GPS ...
xgody Google Search
Apr 18, 2017 | Cars & Trucks
I have a Garmin 250W. Is it possible to search and target a location by latitude and longitude rather than post code in France
You can definitely route using co-ordinates, this search option can found under "Where To?" it may be located a couple of pages down so go through the pages to see "Co-Ordinates" from here you would be able to enter your latitude and longitude.
Hope this helps!
Apr 26, 2011 | Garmin nuvi 250W GPS Receiver
We are going to Europe and using Camping Cheques Brochure but the GPS Coordinates are as such L49degrees 0'10"1:2degrees56'28" but my Garmin Sat Nav Coordinates only give me a choice of N,S,E,or W can you...
I would suggest that you go to a web site that will take those co-ordinates that you have, enter them and then get or have the program show you the other co-ordinates that you need and can use, Also you may want to check in the sub menu on the gps unit, sometimes some of them have the ability to switch to different co-ordinate system, but this is sometimes, not always. Hope this helps
May 10, 2010 | Garmin nuvi 255W GPS Receiver
I have already asked my question. My new garmin gps 60cx it is giving the wrong locationj coordinates. I was kicked off the chat. I would like my answer without having to pay a 2nd fee. please e-mail it...
It is probably giving co-ordinates in a different format. Go to setup and change the co-ordinates format to hddd.dddd and see if this solves your problem.
Oct 12, 2009 | Garmin Gpsmap 60cx Handheld Gps
Apr 02, 2009 | Garmin GPS 12 GPS Receiver
  2. Select Units
Jun 14, 2008 | Garmin eTrex GPS Receiver
GPS Logo
105 people viewed this question
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
