No red light on, tried it w/and w/o it plugged in. Doesn't look like there are staples jamming it though.
SOURCE: Swingline optima 45 electric stapler cartridge won't reset
call gbc 1-800-541-0094 it has a 5 year warranty. they will send a new one.
SOURCE: Stapler (Swingline 211xx) has jammed. It is electr...
Turn the stapler over, remove the batteries, then remove the black pads and the four screwa under them. Take off the bottom cover and you will see the clear tabs of the cover sticking through the bottom plate. Pust them with a screwdriver toward the center of the stapler while squeezing the cover from the other side. Chances are that you will find the plunger that drives the staples is misaligned. Bend it gently forward or back until it moves without binding. Good Luck!
Most likely a staple is jammed near the discharge end. Get a small screwdriver or pick and try prying out any stuck staples. Usually a little force will pop the release tray out.
