Question about Denon Audio Players & Recorders
I have a denon April s470h receiver and was listening to it today on a low volume when all of a sudden the volume went to the max. Turned it off by the remote and a minute later the receiver turned back on at full volume, had to unplug. Has anyone had this problem?
Posted by Jim Macdonald on
Grubhead
  • Denon Master
  • 5,720 Answers
You will need an engineer for this. The volume control is on these machines controlled by an IC or chip. That sometimes goes faulty and needs to be replaced. They have often a great deal of pins that solder on to the board and need special tools to get them on and off.
Posted on Jun 05, 2021
5 Related Answers
Brian Merry
SOURCE: overheating?
I know this post is pretty old, but I just came across it. I have a GTP-750 that I have fixed. They do run extremely hot which causes the rectifiers in the power supply to fail. I have the rectifier part numbers to fix it as well as cooling method. I have been running mine now for about a year after fixing it sometimes at high levels for extended amounts of time and the case is now barely warm. If you need advice or pictures of my setup send me an e-mail
Posted on Apr 26, 2007
snakehead
Henry Thomas
  • 1074 Answers
SOURCE: AV-DV75 volume control not working
Hi Deebo check the following website www.dalsani.com www.repairworld.com good luck open the set and you will find the part number printed on the body of the component. NB.but i am in the belief that it IS your IC that is damaged.
Anonymous
  • 3130 Answers
SOURCE: Denon UD-M50 amp/3 cd changer
The tact switch behind the panel is being pushed in by a defective front panel button, the small switch is bad behind the button, or the volume control IC is bad. Good Luck
Posted on Aug 13, 2007
Anonymous
  • 65 Answers
SOURCE: Listening Volume
Go to this website and download the manual. http://service.us.panasonic.com/operman/findmanual.aspx?model=KXTG6021
This model has voice enhance feature. There is a volume control on the answering machine and the handset. This manual will show you how to adjust both.
Posted on Feb 08, 2008
Anonymous
SOURCE: volume issue
I have the same problem. When I adjusted the volume on the cable box, it was solved. Turn up the volume on the cable box, and when you use your remote, it's super loud, even at midway!
Posted on May 20, 2008
Denon problems
I'm not familiar with your unit. However, go to systems surround set up and turn up volume for those surround speakers you speak of.
2answers
I have a Denon Receiver, that recently started having volume problems. after listen to any source for about 40min to an hour, the volume either totally cuts out or increases to max volume. This condition...
The control section seems to have a thermal problem, when its cold it works, then warms up(metals expand with heat) it loses a connection. Can be either a solder connection or a component, these are found with freeze spray by a qualified technician.
Excessive noise in my speakers
usually, it is background noise. Scratchy background noise. Gets worse the louder I turn up the volume. I ran a test on all the channels and it seemed to be the subwoofer channel. I've unpluged the subwoofer but that didn't help. I have also noticed that my receiver doesn't turn up nearly as loud as it used. I usually watch DVDs at a volume level of about 15 on my Denon and that's quite loud. But now, 15 isn't that loud at all. I went to Best Buy where I bought all of this equipment and they immediatly told me it was suge protector issue and wanted to sell me a high-end surge protector. Perhaps they are right but not sure why it began rather suddenly. Probably not helping you much.
7helpful
2answers
Kenwood TS50 - Max volume gives very low audio while receiving
It sound like a bad reostat in the volume control. if its under warranty send unit back to kenwood and have them replace the volume control, and possible speaker involvement.
2answers
No sound when on internet radio, playtime is running, volume is not muted, internet ok
It was solved by turning the receiver off with the power button (not stand-by). After turning on the netradio did have its sound back. Apparantly it must be running some sort of Windows os.
Volume settings
Check that level setting for speakers as well as sound field are the same for each input mode. Some receivers will have different max volume levels depending on these settings.
Subwoofer Connection Problem
why don't you both return these units and call Denon for replacements without these problems?  Sqeaky hinges get the oil.
2helpful
Denon avr-5600 protection circuit.
My AVR 5600 has worked flawlessly for nearly 9 years!
Suddenly, when trying to play music (DVD or CD) through my LS32's (JBLPro), once I achieve higher volume, the receiver cuts off.... Using a Symetrex mixer, NO OVERLOAD light on the Denon, it simply cuts off!
Re-cut all the wire connectors... TV movies (5.1) work great at normal listening volumes.... but tonight, when cranking up music, the receiver simply cut off. Blinking light...
HELP
[email protected]
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
tina gallow
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
